Kubota L3200 stalled after running kerosine
   / Kubota L3200 stalled after running kerosine
Mine was definitely a case of 'haste makes waste'.
I'd promised the GF I'd help her with some maintenance at her office at 10:30, was trying to get the mowing done before pulling off to do that. Didn't want to waste time going to town if I had enough of a suitable fuel at home. . . lesson learned for sure. Now I have a broken tractor and still didn't get the mowing done and it's a day later.
Anyway, yeah, kerosene is bad in diesel tractors. Tell your farmer buddies. Not that they'll listen.
My day job is locksmith and trust me, I've seen lots of old-timer advice dispensed and followed relative to my trade with equally disastrous results. I should know better, but i'd gotten away with it before. . .
   / Kubota L3200 stalled after running kerosine #12
They aren't my farmer buddies... and not my tractor. lol
After working on engines (both gas and diesel) since I was a young lad, I know better. Especially how sensitive the silicon/rubber seals are on the newer machines, including the super high tolerances. No way will I ever put anything into my tanks (gas/diesel) that doesn't say it will work in that fuel type, and even then, I am very cautious.
I am a locksmith too on as my side-business... I know exactly what you mean.
   / Kubota L3200 stalled after running kerosine #13
Locksmith: As you describe it, you only ran the L3200 a short time, like maybe an hour all told or less, before having problems. Granted that an 80/20 kerosene/#2 mix is not a good idea, neither is it going to kill your engine in an hour or two. With near certainty you had something in that kerosene you added that you do not know about. No idea what it was, nor does it matter. Just clean everything out thoroughly (as you have almost already done) , make sure you have good clean fresh fuel up to and past the lst filter. Then run it for quite a while (long enough to make sure whatever the impurities were are cleared out of the injection pump, the injectors, etc.) Bythe way, #1 fuel oil = kerosene does not have zero lubrication characteristics, it is just not as good as the #2. I'm betting that if you really get it thoroughly cleaned out you will have no long term damage or worries. Most people have no way to get fuel analyzed but it would be neat to find out what all was really in that kerosene you added. Chances are that droplet size of whatever goo you accidentally added is not making it through your injection system. You may end up having to take loose the injectors and make very sure each line is squirting a good stream.
I do not (so far) believe you have a serious crisis
   / Kubota L3200 stalled after running kerosine #14
Stopping at the same spot over and over implies some sort of mechanical issue interjected into this... at least to me.
   / Kubota L3200 stalled after running kerosine #15
Every time I hear people running kerosene in diesel engines these days I cringe. There is no lubricity in kerosene. To me, it's like running parts cleaner through a diesel engine. ... , but they said their "farmer buddies" told'em they been doing it for years in their diesel tractors. At least when they have an early wear related issue, I'll be the first to tell them, I told ya so.
diesel85: I have to disagree about #1 fuel oil lacking lubricity. See http://biodiesel.org/docs/ffs-performace_usage/lubricity-benefits.pdf?sfvrsn=4 On pp. 3 of that article is a table showing the lubricity of various percent biodiesel as it affects #1 and #2 fuels. For our purposes here, our interest is only the top row in the table (at 0.0% biodiesel) and the HFRR Scar depth in microns is listed for both #1 and #2. The HFRR "scar depth" is a standardized depth of scaring on a specific metal by a specific test tool at controlled speeds, time duration, etc. in other words an industry standardized way to measure the effectiveness of various liquids in lubricity. The numbers are in microns (millionths of an inch.)
Bottom line is that #2 fuel gives 536 microns of scar depth in the same test conditions where #1 (kerosene) gives 671 microns of scar depth. The important thing to note is that the scar depth is not an absolute but rather an excellent RELATIVE measure. So the #1 fuel gives about 25% deeper scars compared to #2 fuel. Not overwhelming, not abusive, not a big deal.
Yes, there is less lubricity in#1 compared to #2 -- about 25% -- but it is not catastrophic and certainly not going to seriously damage someone's injection pump or injectors in a short period of time.
   / Kubota L3200 stalled after running kerosine #16
It's funny you ask... they shrug and tell me the same line: their "farmer buddies" told'em they been doing it for years in their diesel tractors.
Kero today, and engines today are not the same as they where years ago. You can mess stuff up really fast using Kero.
   / Kubota L3200 stalled after running kerosine #17
There's someone at my work that swears by mixing kerosene in diesel, even during the summer in a brand new BX. I told them not to, but they said their "farmer buddies" told'em they been doing it for years in their diesel tractors.
The fuel was much different "back in the day". (so were the engines)
   / Kubota L3200 stalled after running kerosine #18
Enough w/ the lubrication..
IF he has fuel UP TO the inj. pump & nothing out.. guess what??
If fuel IS pumping out of the pump.. take 1 or more injectors out of the block.. turn them up, spin the engine & SEE if they're squirting.. SIMPLE AS THAT..
STAY AWAY from the spray.!!
   / Kubota L3200 stalled after running kerosine #19
Exactly. I would never think of putting a drop of kero in a DPF system...
That's why I was shocked when they told me... brand new BX and running kero and diesel in the summer because their "farmer buddies" told them it was good for it.
Don't care, it's not my machine... my BX2200 gets straight up diesel, with a tiny bit of the gray bottle Power Service after every oil change... been running that since we bought it in 2002.
   / Kubota L3200 stalled after running kerosine #20
I agree I do not think running kerosene that short of time hurt it. I am also betting it had some water or dirt.
A BX, new or older is still pretty basic and forgiving of fuel. They have no emissions systems. Running kerosene does not make sense except in the winter mainly because it costs more
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2011 NEW HOLLAND C227 SKID STEER (A52709)
2011 NEW HOLLAND...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
TARTER CATTLE MASTER HEAD GATE (A58374)
TARTER CATTLE...
2007 Ford Ranger Pickup Truck (A56858)
2007 Ford Ranger...
