Kubota L3130
/ Kubota L3130 #1
dgage2
Kibitz L3130
The Intellipanel service inspect light will not reset, even though the hours do. Is there another way to get the light to reset?
Dick
/ Kubota L3130 #2
I am guessing you are trying this as per manual and holding both buttons down?
/ Kubota L3130
Yes. In the past, this worked. But, now, nothing happens.
/ Kubota L3130 #4
Make certain it is in the Hour Meter display before pressing the two buttons to reset.
Per the IntelliPanel glossy that came with the tractor.
/ Kubota L3130 #5
Mine did the same thing this week. I didn't want to hunt my glasses down, so I just rotated through a combination of all the settings holding both buttons down each and it went off.
My Operator Manual says to press the switch to traveling mode then press both down for two seconds.
/ Kubota L3130
I did this per panel sheet, but it does not shut light off. Thanks
/ Kubota L3130 #7
Did you try all settings? Mine didn't shut off the first couple of times either until I tried all settings a couple of times; first time I ever had it happen.
/ Kubota L3130
I will try it again, going through all settings a couple times, to see if it will work. Thanks for your advice.
/ Kubota L3130
I finally got back to our property, and the sequence you suggested did work on the second try of going through all of the settings and doing the reset. Thanks for sharing your knowledge.
Dick
/ Kubota L3130 #10
Dick
Glad to hear it worked for you, mine has only done that once and I have absolutely no idea why.
Iranch High-End Tricycle (A64119)
Iranch High-End...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2018 P.J. Trailer Trailer, VIN # 4P5F82023J1283348 (A65563)
2018 P.J. Trailer...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
