Kubota l3130 split pin plug leaking.
/ Kubota l3130 split pin plug leaking. #1
Andyandlily
springfield oregon
kubota l3130
I have a l3130 that is leaking hydraulic fluid from the spilt pin plug and i want to know what that means.
/ Kubota l3130 split pin plug leaking. #2
:welcome: To TBN
/ Kubota l3130 split pin plug leaking. #3
If you are talking about the one in the clutch housing, I think there is an old thread on here somewhere, but I can't find it, sorry.
yes the one in the clutch housing. i think from what i read on here that its the input shaft seal. how much of a pain in the butt is it to change?
/ Kubota l3130 split pin plug leaking. #5
Wish I could help, but on stuff like that my solution is to call Davis Farm Supply and have them come pick it up.
/ Kubota l3130 split pin plug leaking. #6
Try posting your question in the specific Kubota forum here on TBN. Welcome aboard and best wishes.
/ Kubota l3130 split pin plug leaking. #7
If hyd oil it's the seal or gasket in the housing that the shaft goes in, behind the cluch bearing. If it's black engine oil it's the rear main seal. Eather way the tractor has to be splite. When apart check the housing and make sure it is flat. Not a hard job just a lot of time.I had to do it on my L4240.
By the way to get the housing off there are 2 holes that are threaded all the way thru and you screw a bolt into them and it backs the housing off.
/ Kubota l3130 split pin plug leaking. #9
Welcome to TractorByNet! :smile:
I moved your thread to the Kubota Owning/Operating forum.
2011 Freightliner M2 106 Medium Duty T/A Dump Truck (A61573)
2011 Freightliner...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
SCAN TO RECEIVE TEXT UPDATES (A64276)
SCAN TO RECEIVE...
John Deere 5525 (A60462)
John Deere 5525...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
2014 International WorkStar 7500 T/A Dump Truck (A61573)
2014 International...
