kubota L3010 mower
   / kubota L3010 mower #1
Anonymous Poster
Epic Contributor
I need advice as to whether i need a RMM or MMM, side discharge/rear discharge, 5, 6 or 7 foot finish mower for my tractor. Will be cutting around 8 acres on a weekly basis, fairly flat, some small trees that my wife has planted.
thanks
   / kubota L3010 mower #2
Don-There are good and bad points about having either a MMM or RMM. I can tell you that a 3010 will easily handle a 72" mower and a 84" mower if you mow frequently. If you get a RMM, I would recommend a rear discharge. Do a search and you will find more than you want to know about mowers. Each individual has his own preference. A RMM is also quite a bit cheaper than a Kubota MMM..
   / kubota L3010 mower #3
Unless your tractor is going to be a dedicated mowing machine ask how easy it is to install and remove the mmm for that model tractor. If it's like mine, it's a b*tch. An RFM will be a lot easier to hookup and remove.
   / kubota L3010 mower #4
Don124
I prefer the RMM with a side discharge. 1) because the RMM is so easy to remove and replace. 2) the side discharge allows me to attach a leaf vaccum in the fall to pick up all the leaves the trees leave. I did have to make a hitch on back of the mower deck to attach the vac to. Sure beats a rake when there is 3 acres of grass with lots of trees.
I wish you well.
Gil
   / kubota L3010 mower #7
i have a 72 rmm on my 3010, i love it, rear discharge and it will cut grass at about any height. leaves it looking nice.
just my 2 cents /forums/images/graemlins/smile.gif
does the rear discharge leave clumps of grass like a bushhog does? also, what brands seem to be of higher quality? I don't necess. have to have a manicured lawn, but would like it to look nice.
thanks for all the good info,
don
   / kubota L3010 mower #9
Bill, I sure hope I haven't talked out of turn but there is a recent thread talking about the lack of clearance with R4 tires and a MMM on the Kubota L tractors. Seems like poor planning on Kubota's part and I am a Kubota fan.
Mrhurt, what type of tires are you running on your 3010?
MarkV
   / kubota L3010 mower #10
I have a LandPride 60" rear mount rotary mower and it cuts great. My orchard looks terrific. I could have gone with a bigger rotary deck and may do that some day but I see no reason to go with a MMM.
378621 (A51573)
378621 (A51573)
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
378576 (A51573)
378576 (A51573)
2018 INTERNATIONAL BOX TRUCK (A52472)
2018 INTERNATIONAL...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
