kubota L3010 mower
   / kubota L3010 mower #1
Anonymous Poster
Epic Contributor
I need advice as to whether i need a RMM or MMM, side discharge/rear discharge, 5, 6 or 7 foot finish mower for my tractor. Will be cutting around 8 acres on a weekly basis, fairly flat, some small trees that my wife has planted.
thanks
   / kubota L3010 mower #2
Don-There are good and bad points about having either a MMM or RMM. I can tell you that a 3010 will easily handle a 72" mower and a 84" mower if you mow frequently. If you get a RMM, I would recommend a rear discharge. Do a search and you will find more than you want to know about mowers. Each individual has his own preference. A RMM is also quite a bit cheaper than a Kubota MMM..
   / kubota L3010 mower #3
Unless your tractor is going to be a dedicated mowing machine ask how easy it is to install and remove the mmm for that model tractor. If it's like mine, it's a b*tch. An RFM will be a lot easier to hookup and remove.
   / kubota L3010 mower #4
Don124
I prefer the RMM with a side discharge. 1) because the RMM is so easy to remove and replace. 2) the side discharge allows me to attach a leaf vaccum in the fall to pick up all the leaves the trees leave. I did have to make a hitch on back of the mower deck to attach the vac to. Sure beats a rake when there is 3 acres of grass with lots of trees.
I wish you well.
Gil
   / kubota L3010 mower #7
i have a 72 rmm on my 3010, i love it, rear discharge and it will cut grass at about any height. leaves it looking nice.
just my 2 cents /forums/images/graemlins/smile.gif
does the rear discharge leave clumps of grass like a bushhog does? also, what brands seem to be of higher quality? I don't necess. have to have a manicured lawn, but would like it to look nice.
thanks for all the good info,
don
   / kubota L3010 mower #9
Bill, I sure hope I haven't talked out of turn but there is a recent thread talking about the lack of clearance with R4 tires and a MMM on the Kubota L tractors. Seems like poor planning on Kubota's part and I am a Kubota fan.
Mrhurt, what type of tires are you running on your 3010?
MarkV
   / kubota L3010 mower #10
I have a LandPride 60" rear mount rotary mower and it cuts great. My orchard looks terrific. I could have gone with a bigger rotary deck and may do that some day but I see no reason to go with a MMM.
2004 Chevrolet Suburban (A50120)
2004 Chevrolet...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2002 Peterbilt 379 (A50120)
2002 Peterbilt 379...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2012 Chevrolet Captiva Sport SUV (A50324)
2012 Chevrolet...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
