kubota L3000dt thermostat
   / kubota L3000dt thermostat #1
tomt9857
kubota L3000dt
I have a 2004 Kubota l3000dt with 600 hrs. never flushed the cooling system which I am going to do now. What is involved in changing out the thermostat?
Thanks in advance
   / kubota L3000dt thermostat #2
Should be easy new thermostat and gasket or gasket sealer (Permatex ) Don't over tighten the bolts you will break the housing .. Clean both sides good.
Thanks sounds good
Any tips I should know about flushing the coolant system? Thanks
   / kubota L3000dt thermostat #5
If you want take the bottom hose off also ,when the thermostat is out use garden hose to flush out the motor and radiator cold motor only see how much the system holds you never get all the water out ,So if it holds 6 quarts put in 3 quart anti freeze then top off with distilled water $1.00 at wally world.......
   / kubota L3000dt thermostat #6
concentrated antifreeze you add the water to make it 50/50 not the premixed stuff its already 50/50......
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2008 Ford Focus Sedan (A53424)
2008 Ford Focus...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
