kubota L3000dt thermostat
   / kubota L3000dt thermostat #1
tomt9857
kubota L3000dt
I have a 2004 Kubota l3000dt with 600 hrs. never flushed the cooling system which I am going to do now. What is involved in changing out the thermostat?
Thanks in advance
   / kubota L3000dt thermostat #2
Should be easy new thermostat and gasket or gasket sealer (Permatex ) Don't over tighten the bolts you will break the housing .. Clean both sides good.
Thanks sounds good
Any tips I should know about flushing the coolant system? Thanks
   / kubota L3000dt thermostat #5
If you want take the bottom hose off also ,when the thermostat is out use garden hose to flush out the motor and radiator cold motor only see how much the system holds you never get all the water out ,So if it holds 6 quarts put in 3 quart anti freeze then top off with distilled water $1.00 at wally world.......
   / kubota L3000dt thermostat #6
concentrated antifreeze you add the water to make it 50/50 not the premixed stuff its already 50/50......
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
2005 Nissan Pathfinder SUV (A55758)
2005 Nissan...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
