Kubota L285
/ Kubota L285 #1
HNSTABE
Plain City, OH
Kubota L285
Kubota L285 Starter solenoid clicks, is this an easy fix? BTW I have or 15 different attachments for this tractor.
/ Kubota L285 #2
Check battery connections first.
/ Kubota L285
I'm looking for someone that has taken this starter/solenoid apart.
/ Kubota L285 #4
You listed a symptom of the starter solenoid clicking. Thomas gave you the first step in troubleshooting. To that I would add have the battery load tested. It is usually less expensive to begin with a systematic approach to troubleshooting than to start by disassembling things.
/ Kubota L285 #5
After checking the battery and battery connections, try to crank it again. If still nothing, take a look at the solenoid. There well be two large wires to the solenoid. One goes to the battery, the other to the starter motor.
jump across those two large terminals and the starter motor should turn....so be ready for it.
Whether or not the turning starter motor engages the flywheel or not depends on what type of bendix or similar engagement engagement mechanism is in your particular starter+solenoid combo.
If this test causes the starter motor to spin, then you can rebuild/replace the solenoid.
/ Kubota L285 #6
And if the starter doesn't spin, then most likely the starter needs rebuilt, as in cleaning, brushes and bearings.
SR
/ Kubota L285 #7
SR
Yes, that's what I'd do. Many times OEM starters are much better after a rebuild than replacing the original with a box store aftermarket starter.
After you've done a few - and it sounds like you have - then you know that most of a starter rebuid is simply cleaning and sometimes replacing the brushes.
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
SY225C SY225C9C5KL EXCAVATOR (A59823)
SY225C SY225C9C5KL...
UNUSED IRANCH 39" HYD MINI DOZER BLADE (A60432)
UNUSED IRANCH 39"...
2019 LGMG SS1932E ELECTRIC SCISSOR LIFT (A60429)
2019 LGMG SS1932E...
