Kubota L285
/ Kubota L285 #1
HNSTABE
Plain City, OH
Kubota L285
Kubota L285 Starter solenoid clicks, is this an easy fix? BTW I have or 15 different attachments for this tractor.
/ Kubota L285 #2
Check battery connections first.
/ Kubota L285
I'm looking for someone that has taken this starter/solenoid apart.
/ Kubota L285 #4
You listed a symptom of the starter solenoid clicking. Thomas gave you the first step in troubleshooting. To that I would add have the battery load tested. It is usually less expensive to begin with a systematic approach to troubleshooting than to start by disassembling things.
/ Kubota L285 #5
After checking the battery and battery connections, try to crank it again. If still nothing, take a look at the solenoid. There well be two large wires to the solenoid. One goes to the battery, the other to the starter motor.
jump across those two large terminals and the starter motor should turn....so be ready for it.
Whether or not the turning starter motor engages the flywheel or not depends on what type of bendix or similar engagement engagement mechanism is in your particular starter+solenoid combo.
If this test causes the starter motor to spin, then you can rebuild/replace the solenoid.
/ Kubota L285 #6
And if the starter doesn't spin, then most likely the starter needs rebuilt, as in cleaning, brushes and bearings.
SR
/ Kubota L285 #7
SR
Yes, that's what I'd do. Many times OEM starters are much better after a rebuild than replacing the original with a box store aftermarket starter.
After you've done a few - and it sounds like you have - then you know that most of a starter rebuid is simply cleaning and sometimes replacing the brushes.
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A61567)
2014 Jacobsen AR3...
New/Unused Quick Attach Double Hay Spear (A61166)
New/Unused Quick...
2006 JLG 2630ES ELECTRIC SCISSOR LIFT (A62129)
2006 JLG 2630ES...
2001 Freightliner MB55 Bus (A61568)
2001 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
