Kubota L2800HST won't start
   / Kubota L2800HST won't start #1
GCLnIndiana
Central Indiana
LA2800 HST
Hooked up my new finish mower (60" cub cadet) today. Went into town to buy a qt of gear oil and came back. The tractor wouldn't start. Only clicks. Checked battery, its fine. The tractor only has 54 hrs on it. Would the starter/solenoid be the next suspect? Does the clutch have a switch that keeps the tractor from starting if its not depressed? Could that be a suspect? In the meantime, the grass continues to grow.
   / Kubota L2800HST won't start #2
YES! At least my L3940 HST does. It's so you can't have your foot on the HST pedal, crank it & haul arse without really intending to!
On my fancy pants Grand L, if you try to start it without the clutch in, the digital display says CLUTCH ... Haha, true story!
   / Kubota L2800HST won't start #3
If it is clicking the safety interlocks are probably working the solenoid is not getting enough power, try charging the battery. There is a switch on the Clutch pedal.
   / Kubota L2800HST won't start #4
Make sure the PTO is off.
Yes you have to have the clutch pedal pushed down.
Make sure HST pedal is centered(sometimes you have to be in the seat and rock it back and forth with the key on to catch this).
The safety switches are a pain sometimes.
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
Steiner Front Cut Mower (RUNS) (A50774)
Steiner Front Cut...
2018 JLG 3246ES 32FT Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2019 Kubota F3990 72in Commercial Mower (A50322)
2019 Kubota F3990...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
