Kubota L2800
/ Kubota L2800 #2
It’d probably lift it off the ground but if you’re stacking 800-1000lb round bails up high it could induce instability on a 2600lb 63in wheelbase machine. Would definitely want to have the tires loaded and ballast on the 3pt.
/ Kubota L2800 #3
Based on my experience with an L3200, I don't think it will lift a round bale safely, and I also suspect you're guessing wrong. Get the numbers right and then compare directly to the loader specs to know for sure.
/ Kubota L2800 #4
As already said rear tires loaded also R4 tires little better for higher lift.
/ Kubota L2800 #5
I'd go bigger for large round bales. You could move them with a rear bale spear like I used to on my L3710. I tried lifting a large bale with bucket forks once and it wouldn't do it. I'm sure it would have with a bale spear loader attachment. That said, the loader for a L2800 is considerably smaller.
TractorData.com Kubota L371 tractor attachments information
Loader: Loader type: Kubota LA681: Height (to pin): 102.4 inches [260 cm] Clearance, dumped bucket: 80.3 inches [203 cm] Dump reach: 23.4 inches [59 cm] Dump angle: 40: Reach at ground: 66.5 inches [168 cm] Rollback angle: 23: Breakout force (lift): 2557 lbs [1159 kg] Lift to full height (at pin): 1499 lbs [679 kg] Bucket width: 60 inches [152 cm] 66 inches [167 cm]
TractorData.com Kubota L28 tractor attachments information
Kubota LA463: Height (to pin): 95.3 inches [242 cm] Clearance, dumped bucket: 76.2 inches [193 cm] Dump reach: 22.2 inches [56 cm] Dump angle: 40: Reach at ground: 64.5 inches [163 cm] Rollback angle: 31: Breakout force (at 500mm): 1,858 lbs [842 kg] Lift to full height (at pin): 1,142 lbs [518 kg] Lift to full height (at 500mm): 853 lbs [386 kg]
I'm interested to see if anybody uses a tractor that small though.
Kevin
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
40in. Skid Steer Tree Spade (A65640)
40in. Skid Steer...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
Hobart Beta- Mig 200 Welder (A65579)
Hobart Beta- Mig...
Landhonor 48" Galvinized Fence (A66408)
Landhonor 48"...
