Kubota L2800 fuel solenoid connector.
   / Kubota L2800 fuel solenoid connector. #1
Boatman62
Mill Spring, NC
Farmall H, JD 4110, Kubota L2800, Kubota BX1870
I need to replace the connector that attaches to the fuel solenoid. Really only need the pins but will buy the whole unit if needed. Below is a link to the connector I need but it's too pricey and I don't know if it comes with the pins. I checkers the parts give and only found it as part of the witing harness. Any suggestions???
1C:)6583 Kubota - Connector - 2 way | Omega Parts International BV
   / Kubota L2800 fuel solenoid connector. #2
Can you just solder the wires together and use heat tape over the top?
This connector plugs directly onto the solenoid. If it were a matter of just 2 wires that needed to be joined I would do as you suggest.
So will new terminals work ? Just the clips. Not use the rubber casing that Locks in. Could cause a different problem with not locking in i guess.
Disconnects
| Fastenal
That won't really work in this case. Plus none of those are small enough. The male spades on the solenoid are only about 1/16" wide.
   / Kubota L2800 fuel solenoid connector. #6
Well darn. I have heard of several in the forum talking about salvage places for Kubota tractors. Might do some looking for one of those or perhaps someone has a link
SHOULE RM8080 LOT IDENTIFIER 116 (A53084)
SHOULE RM8080 LOT...
10" I BEAMS & 10" CHANNEL IRON UP TO 40' LONG (A51247)
10" I BEAMS & 10"...
UNUSED CFG INDUSTRIAL MX50R EXCAVATOR (A51247)
UNUSED CFG...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
MURRAY GAS PUSH MOWER (A51248)
MURRAY GAS PUSH...
Hydraulic 80mm Quick Coupler (A52384)
Hydraulic 80mm...
