Kubota L2800 fuel solenoid connector.
   / Kubota L2800 fuel solenoid connector. #1
Boatman62
Mill Spring, NC
Farmall H, JD 4110, Kubota L2800, Kubota BX1870
I need to replace the connector that attaches to the fuel solenoid. Really only need the pins but will buy the whole unit if needed. Below is a link to the connector I need but it's too pricey and I don't know if it comes with the pins. I checkers the parts give and only found it as part of the witing harness. Any suggestions???
1C:)6583 Kubota - Connector - 2 way | Omega Parts International BV
   / Kubota L2800 fuel solenoid connector. #2
Can you just solder the wires together and use heat tape over the top?
This connector plugs directly onto the solenoid. If it were a matter of just 2 wires that needed to be joined I would do as you suggest.
So will new terminals work ? Just the clips. Not use the rubber casing that Locks in. Could cause a different problem with not locking in i guess.
Disconnects
| Fastenal
That won't really work in this case. Plus none of those are small enough. The male spades on the solenoid are only about 1/16" wide.
   / Kubota L2800 fuel solenoid connector. #6
Well darn. I have heard of several in the forum talking about salvage places for Kubota tractors. Might do some looking for one of those or perhaps someone has a link
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
1994 Prevost Liberty Coach 40FT Class A Motorhome (A51694)
1994 Prevost...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A51247)
UNUSED CFG...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
