Kubota L2800 fuel solenoid connector.
   / Kubota L2800 fuel solenoid connector. #1
Boatman62
Bronze Member
Mill Spring, NC
Farmall H, JD 4110, Kubota L2800, Kubota BX1870
I need to replace the connector that attaches to the fuel solenoid. Really only need the pins but will buy the whole unit if needed. Below is a link to the connector I need but it's too pricey and I don't know if it comes with the pins. I checkers the parts give and only found it as part of the witing harness. Any suggestions???
1C:)6583 Kubota - Connector - 2 way | Omega Parts International BV
   / Kubota L2800 fuel solenoid connector. #2
Can you just solder the wires together and use heat tape over the top?
This connector plugs directly onto the solenoid. If it were a matter of just 2 wires that needed to be joined I would do as you suggest.
So will new terminals work ? Just the clips. Not use the rubber casing that Locks in. Could cause a different problem with not locking in i guess.
Disconnects
| Fastenal
That won't really work in this case. Plus none of those are small enough. The male spades on the solenoid are only about 1/16" wide.
   / Kubota L2800 fuel solenoid connector. #6
Well darn. I have heard of several in the forum talking about salvage places for Kubota tractors. Might do some looking for one of those or perhaps someone has a link
2025 INDUSTRIAS AMERICA 227T 7' X 22' HYD TILT TRL (A51247)
2025 INDUSTRIAS...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
