kubota L2550 barely moving
   / kubota L2550 barely moving #1
vincik
Any ideas. Last time I used it, it moved great. Now let clutch out and it barely goes in forward or reverse. The lever is in "rabbit" position so it isnt that. Why would it do this all of a sudden, am I missing someting. It really has been a great old rust bucket. Any ideas besides buying a new one. /forums/images/graemlins/confused.gif
   / kubota L2550 barely moving #2
Kinda sounds like clutch trouble, does the PTO work?
What kind of tranny does it have?
didnt try PTO and not sure about tranny.... will check that out tomorrow though, thanks!
If the PTO does work, what might that tell?
   / kubota L2550 barely moving #5
Most 2550's were standard gear drive with a double clutch, if the pto is working it kinda leans towards trouble with the drive clutch disc. Might be well worth picking up a shop manual
and do some reading.
Thanks a lot, yep the PTO is working so I will do a little research as you suggest!
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
2017 NISSAN Maxima (A50324)
2017 NISSAN Maxima...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
