Kubota L1801DT
   / Kubota L1801DT #1
chris laws
kubota L1801DT
HI all
I have just purchased an old tractor to do some slashing on our 16 acre property
It is a kubota L1801 DT
I have never owned nor driven a tractor before and would like some feedback as to where i can learn about using the different gears both for the tractor and the slasher that is fitted on the pto
I look forward to reading the forums on Tractobynet and maybe getting some answers to questions I wil have in the future
regards chris laws
melborne australia :)
   / Kubota L1801DT #4
Welcome Chris
The 1801DT should be similar to the L185DT made in 1983-4 timeframe. I had an L185DT and its a stout tractor that can do a lot. I would imagine you have a 4 or 5' slasher?
Several things - it has a two speed PTO 540 and 1000 so with the rotary slasher / brush hog I would suggest using the 540 speed and running it in 4th Lo gear to start especially if you have a 5' cut.
You have a hi/lo transmission so 8 forward and 2 reverse speeds and depending on what you are cutting 3rd or 4th in lo range should be OK - this is trial and error as you dont want to bog down a diesel by going too fast.
Good luck and post some pictures of your machine!
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2011 Caterpillar 299C Two Speed Compact Track Loader Skid Steer (A52377)
2011 Caterpillar...
2006 John Deere 120C Hydraulic Excavator (A53421)
2006 John Deere...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
