Kubota KX41 track hub concern
   / Kubota KX41 track hub concern #1
Bilser
When I began removing the drain plug in left hub of my Kubota KX41-3 excavator to change the oil in the track drive motors, the entire hub rotated. The other side didn't. I had a heck of a time wedging the hub so I could get the drain plug out. When I called the dealer the mechanic simply said "sometime that happens". He didn't seem to think it was a problem. Does anyone know if that can lead to problems in the future. For example leakage around the hub? Thanks.
   / Kubota KX41 track hub concern #3
I think you will find there is only a o-ring in the cover at some point it might start and seep a little then replace it one side just is tighter in the housing that the other
   / Kubota KX41 track hub concern #4
Thanks Dirthog. Do you think that's something a weekend mechanic can do?
Bill
Bill
   / Kubota KX41 track hub concern #7
Not a hard job believe on that machine you have to just push the cover in and remove the snap ring then pull the cover out and change the o-ring
   / Kubota KX41 track hub concern #8
Thanks again. You've calmed me down Dirthog. The sky is not falling.
JOHN DEERE Z530M LOT IDENTIFIER 160 (A53084)
JOHN DEERE Z530M...
BOX OF WIRE RACK PANELS (A51248)
BOX OF WIRE RACK...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2803 (A50460)
2803 (A50460)
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
JOHN DEERE 7210R LOT IDENTIFIER 257 (A53084)
JOHN DEERE 7210R...
