Kubota KX41 track hub concern
   / Kubota KX41 track hub concern #1
Bilser
When I began removing the drain plug in left hub of my Kubota KX41-3 excavator to change the oil in the track drive motors, the entire hub rotated. The other side didn't. I had a heck of a time wedging the hub so I could get the drain plug out. When I called the dealer the mechanic simply said "sometime that happens". He didn't seem to think it was a problem. Does anyone know if that can lead to problems in the future. For example leakage around the hub? Thanks.
   / Kubota KX41 track hub concern #3
I think you will find there is only a o-ring in the cover at some point it might start and seep a little then replace it one side just is tighter in the housing that the other
   / Kubota KX41 track hub concern #4
Thanks Dirthog. Do you think that's something a weekend mechanic can do?
Bill
Bill
   / Kubota KX41 track hub concern #7
Not a hard job believe on that machine you have to just push the cover in and remove the snap ring then pull the cover out and change the o-ring
   / Kubota KX41 track hub concern #8
Thanks again. You've calmed me down Dirthog. The sky is not falling.
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2010 Ford Crown Victoria (A51694)
2010 Ford Crown...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A51247)
UNUSED CFG...
UNUSED RAYTREE RMT48-48" TRENCHER (A51248)
UNUSED RAYTREE...
