Kubota keys
/ Kubota keys #21
When everyone elses Kubota has the same key, and yours is different, that is precisely what makes that tactic so effective. Security, when it's what "everybody" does, is not nearly as effective.
I am confused!
So if a locksmith files my Kubota key down a bit, no one will be able to start my Kubota with a factory copy original key?
/ Kubota keys #22
I am confused!
Ha!
They won’t be able to start your tractor with the key you filed.
They can still start with the factory copy of the original key.
I get where you are going on the question. Good point.
MoKelly
/ Kubota keys #23
I am confused!
If the locksmith files your key a little bit, you may not be able to start it yourself. They might be able to rekey the switch to require a different key. I think is what your were meaning.
Like previous posters have stated, there are several other simpler methods to make theft harder. If the switch on my Kubota is indicative, it presents little if any barrier to tractor operation. There are only three wires that any halfway knowledgable thief could easily jumper.
/ Kubota keys #24
Well filing down is a bit simple. But I'm sure a proficient locksmith could add or remove some tumbers ( hope that's the right term) from the keyway, and modify a kubota key so only the pair would work. I just say that because I'm not sure a kubota key is in the family of standard blanks.
Many tractors have so much plastic and if equiped with a FEL, are not that easy to jump start. Also, dragging a tractor with lowered FELonto a flatbed could be a challenge too.
The biggest question for starters is whether the Kubota keyway readily comes out. Since all keyways are the same, it may be riveted or pressed in there, rather than having a screw to retain it. It would not be the end of the world, but it would take more effort to remove it and figure out a new way to secure the keyway. And a locksmith probably wouldn't want to deal with that part of the task.
/ Kubota keys #25
I’m not sure how filing the key is going to help anything. At best you’ve accomplished nothing. The factory key will still work and your probably won’t. You’d have to get a new key cylinder to to any good. If you wanted to try an on the cheap and easy approach you could cut the end of a key off and put the cutoff in the cylinder. Then only the cut key would work and the factory key won’t set all the way down.
/ Kubota keys #26
I am confused!
Our Kubota tractor........:laughing:
/ Kubota keys #27
/ Kubota keys #28
YOU REKEY the cylinder. Modify it slightly in a manner that accomodates the modified key if that is what you have to work with. Having a similar blank would give you more options.
Like I took a bunch of new locksets to a locksmith. He took apart the keyways and re-pinned them (that's the word I was looking for) Now certain keys fit certain groups for certain buildings and a master key operates them all. All done with inexpensive off the shelf locks I bought at trade price.
/ Kubota keys #29
Can the Kubota lock cylinders be re-keyed by any locksmith?
/ Kubota keys #30
I rekey locksets myself. Have kwikset, Schlage and weslock rekey kits in my shop. Residential locksets are designed to be rekeyed... I really doubt a tractor lockset can be rekeyed. Who knows how their tumblers are secured.
I replaced the ignition in my kioti, and I believe it was totally sealed as I recall. I’ll need to go look at the old one sitting on the shelf
/ Kubota keys #31
Why not just put an altogether different key set on? Or as others have suggested and/or done, install a master cutoff which they would need to look for.
/ Kubota keys #32
That is what I did!
A battery cutoff.
Cheap on E-Bay.
/ Kubota keys #34
Wow I just leave the keys in my tractors....
/ Kubota keys #36
So did my neighbors. And didn't have a lock on their door. Came home one day and everything was GONE! They were emotionally damaged by the experience!
People always say, it's just stuff, or it's insured, until they experience it and the violation of their perceived safe space.
/ Kubota keys #37
I have been told that people never feel the same about their home safety, after it has once been breached.
/ Kubota keys #38
I have been robbed out of my truck and had a briefcase/wallet stolen. Of course it was the very the ODD time I was carrying a good amount of cash. Trying to figure out who did it and in the case of my briefcase where, almost drove me nuts. I couldn't sleep at my Mom's anymore, only half asleep, aware of every noise. I'm sure if victimized enough, you would get used to it. People do, in high crime areas.
/ Kubota keys #39
All you need to do is get 12v from the battery to the small terminal on the starter solenoid, not hard to do even on a BX.
Using a rollback or a trailer with a winch, put the loader in float, pry the bucket up enough to get the winch line under it, then connect it to the brush guard. No problem at all.
Easier with a tilt bed trailer, but not overly hard without.
If someone wants your tractor and comes with a trailer with a winch and a few tools they WILL get it.
Aaron Z
/ Kubota keys #40
Some new heavy equipment has chip in the key now
Kubota excavator
Units that are ordered to be rentals come with chipped keys. Everything else is standard.
I have been working construction for 30 years, and have personally seen only a few machines stolen. Two Bobcat skidsteers, one Cat, four Case when they first came out with the XT痴, a Cat 950G payloader, (returned the next weekend, perp never caught), a Cat D6N, )new, small style), and the biggest one: a Case Quadtrac 450. Driven over to the road, in-hitched the scraper and dropped it, onto the road and onto a trailer on a Sunday, 500 from a state highway.
Like I said, nothing to worry about.
:laughing:
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
Adams Nurse Trailer Tank (A63688)
Adams Nurse...
