Kubota issues
/ Kubota issues #1
Big Al 1423
Kubota 3010
Hello everyone,
I need help I have a 3100 Kubota and the front bucket will barley pick up but the tilt works good looking for some advice.
Thanks Alex
/ Kubota issues #3
Its may have an adjustment problem in the lever for the bucket. One of my tractors had so much slop the lever wasn't moving the spool far enough to lift properly.
/ Kubota issues #4
Make sure the simple things are eliminated first.
Had a similar problem and it turned out to be one of the hydro lines was not fully seated in the quick disconnect.
/ Kubota issues #6
If you're lucky, all you need to do is shut down the tractor, wiggle all the hydraulic valves (including the 3PH), then disconnect and reconnect all the couplers to the loader and any remotes you have. If you're unlucky, it will be a hydraulic pump. BTDT.
/ Kubota issues #7
I would also make sure your lines are good. ie one of the lines to your loader is frayed and leaking not allowing proper flow. Even just a slight leak will cause a lot of pressure loss and the hydraulic flow may not be enough to lift it.
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
2010 WABASH 53X102 REFRIDGERATED TRAILER (A59914)
2010 WABASH 53X102...
LS MT225E (A64126)
LS MT225E (A64126)
2019 John Deere R-4038 (A61306)
2019 John Deere...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
