Kubota HST Input Shaft Splines Stripped
   / Kubota HST Input Shaft Splines Stripped #1
Hysyde
Eastern Ontario, Canada (South of Ottawa)
While mowing with my old Kubota F2100 front mount mower the other day I came to a abrupt halt accompanied by a grinding noise. It didn't take long to figure out that the coupler coming from the engine/clutch was spinning on the input shaft for the HST.
Replacing the through bolt only got me so far (I snapped 3 to finish the yard) and I switched to a grade 10.9 (up from 8.8) which only got me so far as well.
I realize I brought this on myself as I use the tractor to pull heavy loads of wood out of the bush, and will often rock it back and forth when getting stuck in snow/mud ruts. Not what this tractor was designed for, but it's been a tough machine, taking this abuse for years.
I wondering what my options might be at this point. A look on the Kubota parts finder page puts this shaft at nearly $1200 which is a lot of money to invest in this old girl (about 3500hrs on the meter). Pluis this isn't a job I see doing myself. Pulling the HST doesn't look too bad, but I don't intent on splitting the case myself.
Could I have the shaft built up with weld and new splines machined?
What about welding the coupler right to the shaft, since it's ruined anyway?
Also, what is the purpose of the grease fitting for a coupler that doesn't move on account of the through bolt?
Any recommendations are appreciated.
   / Kubota HST Input Shaft Splines Stripped #2
Gonna go out on a limb and say the coupler (like the ones on mine are made of soft steel whereas the shaft is heat treated). I've replaced my couplers before, they cost 45 bucks each from the dealer and mine takes a roll pin, not a bolt. I believe they all take a roll pin from the factory, not a bolt.
Definitely a possibility and probably something I should try first, as it likely needs replacing either way.
I believe it's a bolt as the parts diagram show a bolt and locknut (and looking up the bolt it describes an M6 bolt).
I think I under stand the grease fitting now as it appears the coupler has a ball joint of some kind, I guess to accommodate whatever driveline flex there is.
   / Kubota HST Input Shaft Splines Stripped #5
Bet it's softer than the spline shaft, like mine is. Kubota isn't dumb about such items.
   / Kubota HST Input Shaft Splines Stripped #6
See if you can't find a browning taper lock hub assembly the same size and spline count as the input shaft. If so then take part #40 to a machine shop and have the hub welded on. Reattach to your input splines and tighten down the taper lock. Chances are it will never come loose again.
Actually a friend of mine did this on the splines of a hydraulic pump. He didn't even use a splined taper lock and the assembly held without slipping.
   / Kubota HST Input Shaft Splines Stripped #7
IT appears the the parts 40 and 50 are part of a CV joint.... IF you are blowing shear bolt/pin 100 then it may be easy to replace the CV joint and not have to deal with $1200 shaft....
Dale
I had "my guy" pull the HST and the shaft comes out relatively easy once you have the HST out. Both the shaft and the ball-joint coupler were demolished.
We talked about various options, many of which he was not comfortable with as he wanted to ensure it didn't end up with imbalance or vibration that could wreck (even more) very costly HST components.
Before I ordered a new shaft, he told me he was going to stop by a machine shop he deals with to see if they could re-spline the shaft. I'm guessing they were going to give it a shot, as I haven't got a call back.....
Again, I was disappointed that this shaft would have failed, then I remember how many times I had gotten bogged down in the mud and snow with a thousand pounds plus behind me. Nevermind the countless years of plowing abuse (II use a blower now on another tractor).
   / Kubota HST Input Shaft Splines Stripped #10
I'm shocked you get along with those turf tires in that terrain and envirnoment. Snow, maybe not so bad, but turfs and mud don't get along.
I had a pretty heavy duty Gravely walk behind. It too wore out the wheel hubs, that went on splined axle shafts. I guess castings are pretty soft by comparison to the hardened shaft.
UNUSED LANDHONOR FW-13-15000G HYD CABLE WINCH (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR RGB-11-72W - 72" ROCK GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
UNUSED IRANCH 16" EXCAVATOR RAKE (A54757)
UNUSED IRANCH 16"...
2024 New Holland T8.410 MFWD Tractor (A55302)
2024 New Holland...
2010 Astec Underground RT660 4WD Trencher Backhoe (A55787)
2010 Astec...
