Kubota Grand L5030 question
   / Kubota Grand L5030 question #1
Pokeboater
Macon, Georgia
John Deere 4520 cab
I'm thinking about buying a L5030 with a cab. I'm concerned that it might not cool enough. I'm in Georgia where it get real hot and real humid. The specs say it has a "temperature differential" of 7 to 14 degrees. If it is 100 does that mean the cab will be 86 to 93 degrees? That doesn't sound like it would be cool enough. The John Deere 4720 cab specs say it has a 30 degree differential that sounds better. I just want to be sure I'm comparing apples to apples with the cabs.
   / Kubota Grand L5030 question #3
i have a m4900 with cab and can say last summer during 95-100 degree summer days i ran the AC on low to keep from freezing. i am in north alabama where it gets hot and humid.
i believe the L tractors have smaller cabs but i dont know if the AC is smaller.
   / Kubota Grand L5030 question #4
   / Kubota Grand L5030 question #5
A lot of times temperature differntial when talking about heating and cooling is how much change in temperature from inlet to outlet temperature...so if the a/c is taking in 90 degree air inside the cab and cooling it say 14 degrees, it will send out 76 degree air ... after it runs a bit if its taking in 76 degree air it will put out 62 degree air, see what I mean?
I don't have a cab on my Kubota but I have never heard anyone say the a/c was anything but nice and cold.
   / Kubota Grand L5030 question #6
That's what I'm concerned about. If it is taking air in at 100 from outside and only cools it 7 degrees to 93 inside or 14 degrees to 86, then that's not going to be cool enough.
   / Kubota Grand L5030 question #9
Sir,
I own a L5030, and i have used the A/C in both winter and summer (so far 92F) temps. The A/C has directional vents that are very effective. If you leave them pointed at you, you will eventually re-direct them. Just for a reference, I like cold temps; where I am from we get winter down to -40. A 25F day in the winter is another mild day:)
Also, remember that you are in the steam bath (S.E. U.S.), and the de-humidifying effects of the A/C will also produce a cooling effect. (A "steamy" day for us is 30% humidity)
You will not be disappointed with the 5030 A/C. One other option for additional cooling/heating is to remove the cab top (a few screws and it's off), and line the top with thin aluminized foil/bubble insulation. A big return for little $/effort.
RFB
   / Kubota Grand L5030 question #10
Sir,
RFB
2014 Nissan Frontier Ext.Cab Pickup Truck (A50323)
2014 Nissan...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2016 Polaris Ranger 800 (A50121)
2016 Polaris...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
