Kubota GR2100 mower deck/PTO
   / Kubota GR2100 mower deck/PTO #1
mpt1123
Hello:
I'm having problems with the mower deck on my Kubota GR2100. It started with the mower engaging/disengaging while mowing. Since I've had the tractor for 11 years I figured it was just an adjustment. I made the adjustment and the mower engages but it doesn't seem to have the power it used to have. It seems to bog down a bit and I'm seeing a little more grass clumping than usual. It seems that the PTO is just not transferring all of the power to the mower deck. Is it possible this is a result of some clutch wear in the transaxle?
Thanks.
   / Kubota GR2100 mower deck/PTO #2
Hello:
Thanks.
You should post this problem in the Kubota lawn and garden forum for quicker responses.If the engine rpm is normal and the deck speed is slowing down it's either the deck belt or the pto engagement clutch.Most likely the clutch and if you keep running it,it could trash the whole transaxle.Having owned this tractor since new,did you have all the available upgrades done under warranty?-like an improved pto engagement mechanism,the new case with bearings instead of bushings on the rear axles,larger charge pump,etc?
I suspect this is a clutch problem. Doing more research on this now. Where can I look to see what 'under warranty' upgrades were offered by Kubota for the GR2100. I bought his tractor new and have had it back to the dealer a couple of times for repairs and nothing was ever said to me about recommended upgrades available from Kubota.
2017 UTILITY 102" X 53' VAN TRAILER (A51247)
2017 UTILITY 102"...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
UNUSED FUTURE HYD MINI EXCAVATOR HEDGE CUTTER (A51248)
UNUSED FUTURE HYD...
JOHN DEERE 7300 LOT IDENTIFIER 18 (A53084)
JOHN DEERE 7300...
JOHN DEERE Q820M LOT IDENTIFIER 229 (A53084)
JOHN DEERE Q820M...
