KUBOTA G6200H BELT ISSUES
   / KUBOTA G6200H BELT ISSUES #1
mustangbd24
I JUST BOUGHT A KUBOTA G6200H WITH 580 HOURS ON IN AND AM HAVING ISSUES WITH THE DRIVE BELTS. I HAVE BURNED THROUGH 2 SETS AND UPON MY LAST INSPECTION NOTICED THE TENSIONER JUMPING AROUND ALOT. WOULD THIS BE THE CAUSE OF THE BELT WEAR? IF SO WHERE CAN I GET ONE? THANKS IN ADVANCE FOR YOUR HELP.
   / KUBOTA G6200H BELT ISSUES #2
good question. I am not at all familar with the g6200 kubota, but after owning a few mowers, but they all seems to work the same way. Is all pulleys and idlers moves freely ? greased ? are the spindles in good shape,greased and can be turned by hand without making wierd noises? are you using oem belts or generics ? have you been mowing tall grasses over 6 inches all the time ? is the spring broken or weak for the belt tensioners ? these are the things i would check first. good luck;)
thanks for the insight, i will check and log my findings
   / KUBOTA G6200H BELT ISSUES #4
i just got a 6200 couple of weeks ago. noticed the belts had chunks off of them. realized the bottom guard was bashed in and rubbing against the belts.
nate
   / KUBOTA G6200H BELT ISSUES #5
Dont use a cogged belt, use a kevlar belt. My 6200 eats cogged belts like candy. If your tensioner pulley is turning freely check your springs and the attenuator pin by the pulley. When I changed over to the non-cogged belt belt vibration was cut in half and belt life tripled
2016 Chevrolet Cruze (A50324)
2016 Chevrolet...
2006 Ford F-150 Pickup Truck (A50323)
2006 Ford F-150...
John Deere 850 Tractor (AS IS) (A50774)
John Deere 850...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
