KUBOTA G6200H BELT ISSUES
   / KUBOTA G6200H BELT ISSUES #1
mustangbd24
I JUST BOUGHT A KUBOTA G6200H WITH 580 HOURS ON IN AND AM HAVING ISSUES WITH THE DRIVE BELTS. I HAVE BURNED THROUGH 2 SETS AND UPON MY LAST INSPECTION NOTICED THE TENSIONER JUMPING AROUND ALOT. WOULD THIS BE THE CAUSE OF THE BELT WEAR? IF SO WHERE CAN I GET ONE? THANKS IN ADVANCE FOR YOUR HELP.
   / KUBOTA G6200H BELT ISSUES #2
good question. I am not at all familar with the g6200 kubota, but after owning a few mowers, but they all seems to work the same way. Is all pulleys and idlers moves freely ? greased ? are the spindles in good shape,greased and can be turned by hand without making wierd noises? are you using oem belts or generics ? have you been mowing tall grasses over 6 inches all the time ? is the spring broken or weak for the belt tensioners ? these are the things i would check first. good luck;)
thanks for the insight, i will check and log my findings
   / KUBOTA G6200H BELT ISSUES #4
i just got a 6200 couple of weeks ago. noticed the belts had chunks off of them. realized the bottom guard was bashed in and rubbing against the belts.
nate
   / KUBOTA G6200H BELT ISSUES #5
Dont use a cogged belt, use a kevlar belt. My 6200 eats cogged belts like candy. If your tensioner pulley is turning freely check your springs and the attenuator pin by the pulley. When I changed over to the non-cogged belt belt vibration was cut in half and belt life tripled
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
Cat 66" Skidloader Bucket (A50774)
Cat 66" Skidloader...
10' Feed Bunk (A50515)
KUBOTA KX165 EXCAVATOR (A51242)
KUBOTA KX165...
BROWNING SOFT GUN CASE, CABELLA SZ 12 CHEST WADERS (A51243)
BROWNING SOFT GUN...
