Kubota Front Loader Model LB552 Hydraulic Lines
/ Kubota Front Loader Model LB552 Hydraulic Lines #1
dbp05ret
Marion, KY
kubota L4300
I failed to mark my hydraulic lines when I disconnected then from the Hydraulic Control Handle that operates the loader. The 4 lines do not have a visible color code on them(white, yellow, blue, red). Is there an easy way to distinguish which one gets connected to the top 2 positions and which 2 get connected to the bottom 2 on the hydraulic control handle? Thanks!
/ Kubota Front Loader Model LB552 Hydraulic Lines #2
I'd call a dealer. Barlow's out your way gets a lot of good press and would probably be able to tell you which goes where.
FENCE PANELS (A58214)
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
DEUTZ MARATHON...
JOHN DEERE 6105E TRACTOR (A62130)
JOHN DEERE 6105E...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A63118)
Mahindra 4550-4L...
