Loader Kubota Front Loader LA953 acting strange
   / Kubota Front Loader LA953 acting strange #1
Little Mouse
Franklin, TN
Kubota
I bought a used Kubota L3830 with the front loader, which had a little over 100 hours in it. Everything worked fine for about 10 hours. Then one day, the front loader started acting weird. It could go up, and the bucket tilted fine, but wouldn't want to come down. So I left it at up position for a few days. The next time I started, it came down, and also it went up about half way, then it started to move up at a snail pace. It also came down very slowly. Eventually, I could get it down all the way, although it took forever. I left it there for a few weeks. Yesterday, I fired it up again, and this time, it went both up and down at a snail pace... About an inch per minute. Today, it could go up a little faster, but took forever to come down. A little later again today, it could go up at a decent speed about half way, then turned into snail, but could come down at a decent speed. All this time, there were no issues with tilting the bucket.
Any ideas what the problem could be?
   / Kubota Front Loader LA953 acting strange #2
Are are the hoses connected properly? Is the oil level correct? Does the curl function correctly? Does the 3 point hitch function correctly. If you have any other hydraulics do they function correctly?
The hose connections are good. My neighbor helped me with checking the oil and hydraulic fluid and he said they are ok. What's the curl and how do I check it? By the 3 point hitch, you mean like 3 point PTO stuff? I've been using the backhoe and it works fine, but it has its own hydraulic. It's probably coincidence, but I started to have problems with the front loader on the day I connected the backhoe. But I didn't want to take it off to see if it's the culprit because I thought it's probably not and it takes two people and hours to put it back on.
   / Kubota Front Loader LA953 acting strange #4
When you tilt your bucket that is often referred to as curl. The 3 point hitch as in pto stuff, yes. Does your backhoe have a separate oil tank and a pto powered pump or does it use hydraulics off the tractor. If I try to use my backhoe and loader at the same time ( like when I get stuck and have two operators). The backhoe gets primary flow which makes the loader very slow. If your backhoe is powered by rear remotes and you were somehow dead heading the remote it might cause the problem at hand.
   / Kubota Front Loader LA953 acting strange #5
When was the last time every zerk on the FEL was greased?
An LA953 Loader is unusually large on an L3830.
   / Kubota Front Loader LA953 acting strange #6
I had a similar experience with a used tractor. It was dirty hyd. fluid was blocking the flow through the control valve. Only certain functions were effected.
Have you changed the hydraulic fluid and filter? I had to flush my system and disassemble the control valve and clean it to get all the gunk out.
4570, curl is good. And my backhoe has its own hydraulics. The only thing it's connecting to is PTO, so theoretically, I thought it shouldn't affect the main hydraulics.
Jeff, I greased everything in the early winter. Since then, I only put about 3 hours in it. Yesterday, I greased everything again just in case, but didn't make any difference. So, you think LA953 is too big? I bought it as a package (used) from the dealer...
Davesl, gosh, I would have no idea how to do all that if I have to do it myself... I'm a completely noob with farm equipment. It probably would cost a fortune if I bring it to the dealer, right? :pessimist:
   / Kubota Front Loader LA953 acting strange #8
Have you tried just resetting the QDs on the loader valve?
   / Kubota Front Loader LA953 acting strange #9
Are you sure it has a la953 loader. Best I can tell that loader doesn't exist. Your tractor should have a LA723 loader.
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55973)
2012 Chevrolet...
48'' ALUMINUM MAN BASKET (A56857)
48'' ALUMINUM MAN...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A55315)
2023 Kubota...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2018 Ford F-350 (A55973)
2018 Ford F-350...
