Kubota frequent belt replacement
   / Kubota frequent belt replacement #1
Washburn
Bel Air MD
Old gravely
Lightly used Kubota L3540HSTC (327 hours in ten years) has needed AC and fan belts replaced every 20 hours in last 40 hour engine time. Any ideas why this is happening?
   / Kubota frequent belt replacement #2
Probably from dry rot. Your tractor is sitting a lot. Is it housed in a controlled environment?
   / Kubota frequent belt replacement #3
are they tensioned correctly, are they the correct size, time to look at whatever pulley both belts run on, you should get several hundred hours out of an engine belt.
   / Kubota frequent belt replacement #4
One of the pulleys is either crooked or dented. You need to examine every one of them.
Ralph
   / Kubota frequent belt replacement #5
bearings starting to go in either an accessory (alt, water pump) or idler?
   / Kubota frequent belt replacement #6
Does it use the "cogged" v belts? I find the roots of the cogs crack and then the cogs start chunking out.
Replace with a standard fabric wrapped non cogged belt of the same size.​
The only reason for the cogged variety is to accommodate very small dia pulleys.
   / Kubota frequent belt replacement #7
Are you using belts from kubota, or a parts store? there may be a slight difference in size.
   / Kubota frequent belt replacement #8
And to add, there are belts intended for various use. Buy good belts. Cheaper is never better.
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
UNUSED FUTURE 24" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 24"...
Bobcat Sweeper/Bucket  72"  (A52384)
Bobcat...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
