Kubota frames the same?
/ Kubota frames the same? #1
8561
Platinum Member
New Hampshire
Kubota B2410 Bi-Speed Turn, R4's, Top 'N' Tilt, LA 352 Loader w/ Toothbar
I have a chance to pick up a sub-frame mount for my backhoe, but I need to be sure of the compatability. I own a B2410. This subframe was designed for a B7510/B1700/B2100. I'm 95% sure the frames between these units is the same, but before I make a decision, I need to confirm the subframe will fit. Anyone know for certain if the 2410 frame is identical to the others I've mentioned?
/ Kubota frames the same? #2
The subframe SHOULD be compatable among those models, but it depends on WHOSE(manufacturer) subframe is it?
Thanks for the reply. I was hoping maybe one of the dealers would chime in. The backhoe and subframe are both Wallenstein. I would think as long as the tractor chassis that these various models are the same, then a subframe built for any one of them should work on any other. That's essentially what I am trying to establish. I already have the subframe that Kubota makes for their own backhoe which is 3 point mounted, as well as the heavy duty top-link. I'm probably fine the way I am, but thought if I could get something that would take the weight off the lift arms, that might be better.
90in. Skid Steer Bucket w/ Blade (A65640)
90in. Skid Steer...
CASE TV450B SKID STEER (A65053)
CASE TV450B SKID...
15ft. Hay Rack (A65640)
15ft. Hay Rack...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
Cute Electric Car (A62679)
Cute Electric Car...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
