Kubota frames the same?
/ Kubota frames the same? #1
8561
Platinum Member
New Hampshire
Kubota B2410 Bi-Speed Turn, R4's, Top 'N' Tilt, LA 352 Loader w/ Toothbar
I have a chance to pick up a sub-frame mount for my backhoe, but I need to be sure of the compatability. I own a B2410. This subframe was designed for a B7510/B1700/B2100. I'm 95% sure the frames between these units is the same, but before I make a decision, I need to confirm the subframe will fit. Anyone know for certain if the 2410 frame is identical to the others I've mentioned?
/ Kubota frames the same? #2
The subframe SHOULD be compatable among those models, but it depends on WHOSE(manufacturer) subframe is it?
Thanks for the reply. I was hoping maybe one of the dealers would chime in. The backhoe and subframe are both Wallenstein. I would think as long as the tractor chassis that these various models are the same, then a subframe built for any one of them should work on any other. That's essentially what I am trying to establish. I already have the subframe that Kubota makes for their own backhoe which is 3 point mounted, as well as the heavy duty top-link. I'm probably fine the way I am, but thought if I could get something that would take the weight off the lift arms, that might be better.
1999 Dorsey 42' Aluminum Citrus Trailer (A64127)
1999 Dorsey 42'...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
40ft Shipping Container (A65583)
40ft Shipping...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
Cherry Wood Boards (A65640)
Cherry Wood Boards...
