kubota FEL chain hooks
   / kubota FEL chain hooks #1
20 20
Elite Member
adirondacks
Hey folks, quick question, I am going to be welding some chain hooks onto a bx3200 kubota FEL and wondered if anyone had any pictures? I have welded hooks onto FELs before and have allways added reinforcement steel 1st. I would also like to add the reinforcement steel on this machine. Any pictures and/or info would be appreciated. The plan is to have 2 hooks. I was thinking of running a 2" piece of angle iron all the way accross then place the hooks on that??? Thanks again for any help.
   / kubota FEL chain hooks #2
Just be sure and weld the hook "in-line" or with the loader's arms. If you weld them on the outside edges - you leave your loader vulnerable to greater side pressures which can result in twisting the bucket or the loader.
   / kubota FEL chain hooks #3
   / kubota FEL chain hooks #4
Make sure and preheat the hook before welding. The forged type hook will crack if it isn't preheated. Just a heads up.
   / kubota FEL chain hooks #5
Yup, that's as important as making sure your have the hooks securely attached if not more. Secure hooks mounted on the outer edges of your loader is a great recipe for twisting our loader arms and/or turning our tractor over. Welding on "pin on" hooks and placing them on the outer edges of the loader bucket are the most common mistakes I see here on TBN. Rather than correct their errors, they try to justify them like "I ain't hurt nuthin' yet" or something similar. That's akin to saying I leave the tavern completely liquored up everyday and I haven't gotten caught or gotten hurt yet. It's a bad idea and, generally, it's just a matter of time. It's a good idea to strengthen most bucket top edges like shown in the one pic, but I'd certainly not mount the hooks on the outer edges as shown. I've cut dozens of those off and relocated them in line with the lift arms for guys. Some before they twisted their loader arms, some after.
   / kubota FEL chain hooks #6
only thing I would add is that I have considered adding 2 hooks facing opposite direction. there have been times when wrapping a load that I did not have anything to hook the chain to to do a complete wrap, like slash, etc.
   / kubota FEL chain hooks #7
I welded one on mine so far, dead center on the rear face of the bucket near the bottom edge. For pulling fence post ends, etc. It's the strongest part of the bucket, and centered between the loader arms. I'm glad I read this thread though, the next ones I add will be in line with the loader arms.
Good idea Bill, if I use the one on the back of the bucket and one on the top lip that'll give me the wrap.
Chilly
   / kubota FEL chain hooks #8
Here's mine :)
   / kubota FEL chain hooks #9
To the original poster, I hope you'll consider adding a third hook in the middle of the bucket, as some others have said. When we bought our tractor new I asked the dealer to put on three hooks but he was reluctant to add any but the center one because of the very real possibility of racking the loader. I convinced him that I understood the danger and intended to use the center hook for pulling and the outside hooks for securing loads for transport in the bucket.
   / kubota FEL chain hooks #10
I had one added to my B3200 and had it placed in the center. May have to zoom to see. This was day one with my B3200. Forks are also in front bucket.
The FEL arms got out of sync on my L3240HST when using Skid Steer QA forks and it was a bad experience. Had to return to dealer for warranty repair since it was only a couple of months old. Weight needs to be centered between fel arms as much as possible but don't become obssessed with it.
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
2016 Chrysler 200 Limited Sedan (A48082)
2016 Chrysler 200...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
PICK UP BED (A49461)
