Kubota factory finish
   / Kubota factory finish #1
GonHuntin
NE, OK
Int 234
Anyone know if the "paint" on the Kubota FEL is powdercoat or electrostatic applied paint??
   / Kubota factory finish #2
What exactly is electrostatic applied paint?
   / Kubota factory finish #4
Perhaps a call to your local Kubota dealer may supply you with the answer? I don't personally know the answer, but in my opinion, I would contact my Dealer. Best wishes.
   / Kubota factory finish #5
I'm interested in the answer. On the B7500 I traded, the paint on the loader frame behaved a lot like powdercoat. A few pieces came off in small "chunks" where moisture had worked in underneath it. The paint on the bucket and sheet metal parts seemed more like normal paint. I sorta thought most paint in assembly line applications was electrostatically applied.
   / Kubota factory finish #7
Sounds like electrostatic paint is just regular/normal paint that is applied similar to powder coat. So it would have all the same characteristics of regular sprayed paint. Just applied differently as to not waste as much in the form of overspray??
Might sound that way, but it's not. eHow.com info is often over simplistic and, many times, just plain wrong.
I spent over a decade working for a Sherwin Williams in their automotive paint division, trust me, the paint you buy at your local Kubota dealer is NOT the same stuff used at the factory.
   / Kubota factory finish #9
I found this info on TBN here from another member. Thought I would pass it along.
One of the painters my company uses paints parts for Kubota. They use
Sherwin Williams:
Primer number: E61YC708
Top Coat number: F63EC31
   / Kubota factory finish #10
Why isn't it the same paint? So if thats true, then how would you go about getting what they use at the factory?
Electric Concrete Mixer (A51573)
Electric Concrete...
INOP Polaris 700 (A51573)
INOP Polaris 700...
PAIR OF 5' PIN ON FOLD UP TRAILER RAMPS (A51247)
PAIR OF 5' PIN ON...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
