Kubota engine rebuild - seeking advice
   / Kubota engine rebuild - seeking advice #1
brad8526
Kubota B8200
I'm not an expert mechanic so I'm hoping anyone with more experience than I would be willing to help me out. I've got a Kubota B8200 that was losing power. I'm replacing the injectors and head gasket and while I have the head off I figured I'd ask you experts on the forum if the cylinder walls of my engine look OK. I took pics from either side and would like to know if you see any problems that should be addressed before I continue.
Thanks
   / Kubota engine rebuild - seeking advice #2
Since you're only doing the head gasket & injectors, from my view, it looks good enough to cap it off and call it done. If you rake your fingernail over the top edge of the cylinder you can get a pretty good idea of how much wear you've incurred. From my chair here though, I think it looks pretty good.
Now - IF you were going to pull the motor, or do any bottom end work, I'd definitely mike the cylinders and see if they need to be re-bored. At a minimum, I'd hone the cylinders and go back in with new rings and bearings. However, I suspect that's much further than you'll want to go.
Thank you Gem99ultra for the reply. I got the head put back on today and I'm still waiting on a cap for one of the valves (I managed to lose one when I took it apart) and after a valve adjustment I'll try firing it up. Wish me luck.
   / Kubota engine rebuild - seeking advice #4
Hope you find that cap though. I lost a wingnut once when doing a pre-race head check on my old Dodge. As soon as I fired it up, I found it. My son, 3 years old at the time, sitting on the fender, and watching Dad work had decided to "help" Dad, and dropped the wingnut down the carburetor. I found pieces of that wingnut in both heads. :mad:
By the way, in my prior post I mentioned "mike" the cylinder. That wouldn't do; "mike" might not like that! My fast fingers should have typed "mic" the cylinders.
   / Kubota engine rebuild - seeking advice #5
That sounds like a spelll check error to me. We knew what you meant anyways, though.
   / Kubota engine rebuild - seeking advice #6
Spellcheck is your worst enema
   / Kubota engine rebuild - seeking advice #7
There really is not enough information to determine an answer for you unfortunately. If I knew the hours on the engine, or if the engine was making WHITE smoke, I might be able to help you better. That is a sign of a blown head gasket.
As for determining the amount of rebuild, there are varying amounts.
I just put a new head gasket in my generator engine (Perkins 4.108). It only had 2607 hours on it, so I did not bother to rebuild the head: it looked pretty good.
Your cylinders looked pretty good to me though.
   / Kubota engine rebuild - seeking advice #8
Cylinders do look good. Good luck,should be fine.
Thanks for the feedback. I got the head back on but i'm currently waiting on a replacement fuel pump to get it running.
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
2018 Land Rover 4WD SUV (A55758)
2018 Land Rover...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A55788)
2005 Isuzu NPR...
(49) 2" X 2" X 98" TUBING (A54756)
(49) 2" X 2" X 98"...
