Kubota cold weather starting
   / Kubota cold weather starting #1
Dogballs
Vermont
I have a Kubota M5040 and regularly use it in below zero temps. I use a block heater to pre-heat the engine, and it starts fine. The problem is the transmission/hydraulic takes forever to heat up once the tractors running. Sometimes I can't even get the tractor to move for a long time.
Has anyone used a magnetic block heater on the transmission? I need to figure out a way to pre-heat it, but I don't want to burn the fluid either.
Thanks for any ideas.
   / Kubota cold weather starting #2
Dogballs, Check out this previous thread, it should answer your questions. If not just do a search on cold weather starting in this thread and you will have a bunch of info, good luck
http://www.tractorbynet.com/forums/...p-tranny.html?highlight=cold+weather+starting
Thanks, that answered my question. I'll try the magnetic heater and see how it works.
   / Kubota cold weather starting #4
What is a "long time" to you? 5, 10, 20 minutes?
I have a M7040 and I usually let it idle for 20+ minutes (having been pre-heated) to let it warm up. Longer if I didn't have it plugged in.
When it's really cold it is sluggish for a few minutes until I start working it.
Depends on the temp. If it's way below zero maybe 20-30 mins.
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53473)
2003 International...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
