Kubota cold weather starting
   / Kubota cold weather starting #1
Dogballs
Vermont
I have a Kubota M5040 and regularly use it in below zero temps. I use a block heater to pre-heat the engine, and it starts fine. The problem is the transmission/hydraulic takes forever to heat up once the tractors running. Sometimes I can't even get the tractor to move for a long time.
Has anyone used a magnetic block heater on the transmission? I need to figure out a way to pre-heat it, but I don't want to burn the fluid either.
Thanks for any ideas.
   / Kubota cold weather starting #2
Dogballs, Check out this previous thread, it should answer your questions. If not just do a search on cold weather starting in this thread and you will have a bunch of info, good luck
http://www.tractorbynet.com/forums/...p-tranny.html?highlight=cold+weather+starting
Thanks, that answered my question. I'll try the magnetic heater and see how it works.
   / Kubota cold weather starting #4
What is a "long time" to you? 5, 10, 20 minutes?
I have a M7040 and I usually let it idle for 20+ minutes (having been pre-heated) to let it warm up. Longer if I didn't have it plugged in.
When it's really cold it is sluggish for a few minutes until I start working it.
Depends on the temp. If it's way below zero maybe 20-30 mins.
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53473)
2017 Rogator...
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
