Kubota cold weather starting
   / Kubota cold weather starting #1
Dogballs
Bronze Member
Vermont
I have a Kubota M5040 and regularly use it in below zero temps. I use a block heater to pre-heat the engine, and it starts fine. The problem is the transmission/hydraulic takes forever to heat up once the tractors running. Sometimes I can't even get the tractor to move for a long time.
Has anyone used a magnetic block heater on the transmission? I need to figure out a way to pre-heat it, but I don't want to burn the fluid either.
Thanks for any ideas.
   / Kubota cold weather starting #2
Dogballs, Check out this previous thread, it should answer your questions. If not just do a search on cold weather starting in this thread and you will have a bunch of info, good luck
http://www.tractorbynet.com/forums/...p-tranny.html?highlight=cold+weather+starting
Thanks, that answered my question. I'll try the magnetic heater and see how it works.
   / Kubota cold weather starting #4
What is a "long time" to you? 5, 10, 20 minutes?
I have a M7040 and I usually let it idle for 20+ minutes (having been pre-heated) to let it warm up. Longer if I didn't have it plugged in.
When it's really cold it is sluggish for a few minutes until I start working it.
Depends on the temp. If it's way below zero maybe 20-30 mins.
2012 FRAC TANK (A53843)
2012 FRAC TANK...
2018 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2018 DRAGON...
2009 DRAGON  130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2013 Volvo BL70B (A47477)
2013 Volvo BL70B...
