Kubota Cold start Issues due to Water build up...???
   / Kubota Cold start Issues due to Water build up...??? #1
mykubota4x4
Kubota B3030HSDC
Hey Folks
Just bought a 2008 B3030, 500 hours, was well kept in heated garage. Everytime we started it fired right up during purchase. It was minus 13c & i transported it. Upon arrival it just started & died. Added new Diesel about 5 litres & diesel conditioner (riesol) with no results, cranked n cranked, even jumpstart didnt work. I see filter has frozen stuff inside. Question is 1. Would this need a complete fuel system flush. 2. More importantly Would this have affected the fuel injectors ?
Appreciate. Thanks.
   / Kubota Cold start Issues due to Water build up...??? #2
Get it warmed up and drain the fuel system. Add new diesel and filter. Might want to check all the oils too.
   / Kubota Cold start Issues due to Water build up...??? #3
are you letting the glow plugs do their job prior to starting?
Definitely change that filter that you say is filled with junk first.
   / Kubota Cold start Issues due to Water build up...??? #4
I would drain all the fuel. put in new filters and winterized fuel.....
Thank you all, Its gelled diesel due to transport in frigid cold climate.,also diesel isnt new either. Will drain and change filters. But otherwise the tractor has good service maintanence records of oil change/filter change. Yes glow plug was used for a good 6 sec or sometimes even 10 sec.
   / Kubota Cold start Issues due to Water build up...??? #7
Use a hair dryer to melt the gel/water. Should start.
Add about 20% kero to the tank if there's room. Otherwise, syphon some out.
Gel will not harm the injectors.
Ralph
   / Kubota Cold start Issues due to Water build up...??? #8
Not sure where your location is, if you can buy some Diesel Service 911 (red container) poor it in the tank, give it some time and it will start, big rigs use it many times - it's started a couple of local tractors that had gelled - after it's running make sure you add the regular Diesel Service (white container).....
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
