Kubota Cold start Issues due to Water build up...???
   / Kubota Cold start Issues due to Water build up...??? #1
mykubota4x4
Kubota B3030HSDC
Hey Folks
Just bought a 2008 B3030, 500 hours, was well kept in heated garage. Everytime we started it fired right up during purchase. It was minus 13c & i transported it. Upon arrival it just started & died. Added new Diesel about 5 litres & diesel conditioner (riesol) with no results, cranked n cranked, even jumpstart didnt work. I see filter has frozen stuff inside. Question is 1. Would this need a complete fuel system flush. 2. More importantly Would this have affected the fuel injectors ?
Appreciate. Thanks.
   / Kubota Cold start Issues due to Water build up...??? #2
Get it warmed up and drain the fuel system. Add new diesel and filter. Might want to check all the oils too.
   / Kubota Cold start Issues due to Water build up...??? #3
are you letting the glow plugs do their job prior to starting?
Definitely change that filter that you say is filled with junk first.
   / Kubota Cold start Issues due to Water build up...??? #4
I would drain all the fuel. put in new filters and winterized fuel.....
Thank you all, Its gelled diesel due to transport in frigid cold climate.,also diesel isnt new either. Will drain and change filters. But otherwise the tractor has good service maintanence records of oil change/filter change. Yes glow plug was used for a good 6 sec or sometimes even 10 sec.
   / Kubota Cold start Issues due to Water build up...??? #7
Use a hair dryer to melt the gel/water. Should start.
Add about 20% kero to the tank if there's room. Otherwise, syphon some out.
Gel will not harm the injectors.
Ralph
   / Kubota Cold start Issues due to Water build up...??? #8
Not sure where your location is, if you can buy some Diesel Service 911 (red container) poor it in the tank, give it some time and it will start, big rigs use it many times - it's started a couple of local tractors that had gelled - after it's running make sure you add the regular Diesel Service (white container).....
2017 International WorkStar 7300 Rosco Maximizer 3B 1,900 Gallon Asphalt Distributor Truck (A52377)
2017 International...
2023 DOOSAN DL220-7 WHEEL LOADER (A52706)
2023 DOOSAN...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
