Kubota clutch repair
   / Kubota clutch repair #1
jacspath
Ulster Co. NY
Kubota L185DT
So here's my story. I have Kubota L185DT with regular tractor tires. It has a front end loader. I am a second owner and have had it for 13 years. Prior own was a resort and it got a bit of abuse, but I knew that when I bought it at a bankrupt sale. I have several 3 point hitch implements [york rake, Kelly B10A backhoe, and 3 rotor PTO drive finish mower deck, etc.]. When I got it, I sensed the clutch was slipping so I adjusted it all the way out and have nursed it for all this time. This spring when I took the backhoe off and put on the mower deck I got 'that smell' which told me that the clutch is about gone. The tractor works fine with good power and the clutch will carry it on a flat surface in hi gear [8th] but almost any up grade will bring the smell. The clutch will run the PTO hydraulic pump for the backhoe with no problem.
Problem: the local Kubota dealer wants $2400 [his estimate without even seeing the tractor so who knows what else will show up] to put in a new clutch. I can't afford that [I'm retired on basically a fixed income but I have plenty of time and a lot of skill but no sophisticated tools]. I need this little critter to adequately maintain my property [12 Ac of meadow, but I do not harvest hay, and woodlot where I cut my firewood to heat my home]. Can anyone help me find online help to help me assess if I can do this job myself and help me find reasonably priced parts? If any of you have done this job in your back yard, I would appreciate your thoughts on what I'm getting into. Thanks all.
   / Kubota clutch repair #3
Hello & WELCOME to TBN!
I moved your thread to the Kubota Owning/Operating Forum. :)
   / Kubota clutch repair #4
Hope this helps....$2,400 sounds real high. Someone borrowed my 02 Kubota L3710 (maybe in 05?) Got it back and that nasty clutch smell was awful. I could smell it when the tractor was parked and shut off. One of the owners of a dealership (where I bought it) fixed it. He said it was the worst clutch he had ever seen. Total was $1,100. He told me to bring the tractor in with the loader and backhoe removed, that would save big money from them having to do it. I think you should get another opinion.
   / Kubota clutch repair #5
see your other thread on this subject for some "how-to" comments - including some links & part prices. I'm sure you can do the job and save most of that quoted price, not to mention have some fun & satisfaction by doing it yourself. Dick B
   / Kubota clutch repair #6
jacspath,
FYI... I sent a private email yesterday.
The following are from TractorSmart.com is your online source for Kubota online parts.
Clutch 67211-13300 Pressure Plate $124.45
Clutch 35120-99150 Clutch Disc $132.20
Clutch 08121-06002 Bearing Pilot bearing. $5.00
Clutch 37150-14820 Bearing, Release $29.20
Good luck!
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
2023 JOHN DEERE 8R370 LOT IDENTIFIER 186 (A53084)
2023 JOHN DEERE...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
Toro ReelMaster Pull-Behind Hydraulic Reel Mower (A51691)
Toro ReelMaster...
1262 (A50490)
1262 (A50490)
