Kubota clock
/ Kubota clock #1
RSF1952
Newtown, CT
Mahindra 2015 HST, Kubota 4060 HST
I was wondering if any other users have seen this glich. I have a 4060 with 14 hours. I was using it yesterday
and noticed the clock was only showing minutes. The hour function was blank.This occurred between 12 and 1
p.m. . From 1 p.m. on, the clock was normal. Shutting down and restarting had no effect. I have not yet been able
to determine if this is a problem with only the 12 o'clock hour,or was this a one time fluke. I welcome all comments
/ Kubota clock #2
You have clock's AM/PM designations reversed.
Read your Owner's Manaual and reset the clock. (Resetting the time takes more fooling than it should.)
/ Kubota clock
Thank you for the reply. How does resetting the clock explain why only the minutes was showing? I guess I don't
understand why it should matter if it is AM or PM
/ Kubota clock #4
Because it is a 24 hour/military time clock. Civilian time resets every 12 hours, military time resets once every 24 hours.
From midnight to 1:00 AM, the hour is "00".
One enlistment in the A/AF/N or Marines will make this clear........
/ Kubota clock
That makes perfect sense. I will look in the manual , and reset
/ Kubota clock #6
Or, you can get your Amatuer Radio operators license
Somewhat less commitment.:)
/ Kubota clock #7
I have often wondered in this modern world that runs 24 hours a day, we bother with the AM PM thing anyway.
/ Kubota clock #8
I think the Puddle Pirates use military time too as does much of Europe.
/ Kubota clock #9
puddle pirate
A US Coast Guard member. derogatory.
Navy Sailor: thanks for staying home and watching the coasts, puddle pirate.
Coastie: Someone needs to keep those navy wives warm at night.
/ Kubota clock #10
puddle pirate
Ouch!!! that was a good one!
/ Kubota clock
When all else fails read the manual. Looking in the owners manual revealed that the clock is only
designed to display the time up to 11:59 after which the clock reverts to 00:00 and starts re-counting.
There is no way to display conventional time. Seems a little to silly to me. I can't believe it would have been
that complicated to design a clock with normal time display. Oh well.
/ Kubota clock #12
You have a Japanese tractor brand, built in Japan.
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
E-Z TRAIL HEADER CART (A63291)
E-Z TRAIL HEADER...
2016 Nissan Altima Sedan. (A61574)
2016 Nissan Altima...
2018 Johnston C201 Compact Street Sweeper (A61572)
2018 Johnston C201...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
