Kubota clock
/ Kubota clock #1
RSF1952
Newtown, CT
Mahindra 2015 HST, Kubota 4060 HST
I was wondering if any other users have seen this glich. I have a 4060 with 14 hours. I was using it yesterday
and noticed the clock was only showing minutes. The hour function was blank.This occurred between 12 and 1
p.m. . From 1 p.m. on, the clock was normal. Shutting down and restarting had no effect. I have not yet been able
to determine if this is a problem with only the 12 o'clock hour,or was this a one time fluke. I welcome all comments
/ Kubota clock #2
You have clock's AM/PM designations reversed.
Read your Owner's Manaual and reset the clock. (Resetting the time takes more fooling than it should.)
/ Kubota clock
Thank you for the reply. How does resetting the clock explain why only the minutes was showing? I guess I don't
understand why it should matter if it is AM or PM
/ Kubota clock #4
Because it is a 24 hour/military time clock. Civilian time resets every 12 hours, military time resets once every 24 hours.
From midnight to 1:00 AM, the hour is "00".
One enlistment in the A/AF/N or Marines will make this clear........
/ Kubota clock
That makes perfect sense. I will look in the manual , and reset
/ Kubota clock #6
Or, you can get your Amatuer Radio operators license
Somewhat less commitment.:)
/ Kubota clock #7
I have often wondered in this modern world that runs 24 hours a day, we bother with the AM PM thing anyway.
/ Kubota clock #8
I think the Puddle Pirates use military time too as does much of Europe.
/ Kubota clock #9
puddle pirate
A US Coast Guard member. derogatory.
Navy Sailor: thanks for staying home and watching the coasts, puddle pirate.
Coastie: Someone needs to keep those navy wives warm at night.
/ Kubota clock #10
puddle pirate
Ouch!!! that was a good one!
/ Kubota clock
When all else fails read the manual. Looking in the owners manual revealed that the clock is only
designed to display the time up to 11:59 after which the clock reverts to 00:00 and starts re-counting.
There is no way to display conventional time. Seems a little to silly to me. I can't believe it would have been
that complicated to design a clock with normal time display. Oh well.
/ Kubota clock #12
You have a Japanese tractor brand, built in Japan.
2025 Auger Bit Skid Steer Attachment (A61572)
2025 Auger Bit...
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59912)
2023 UTILITY VS2RA...
2022 EZ-GO ELITE...
Generator (A61572)
Generator (A61572)
2020 International LT625 48" Sleeper (A62613)
2020 International...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
