kubota Canopies
/ kubota Canopies #1
bpattie
Colorado
i recently got a new kubota tractor, the L series. I did not get canopy but am considering. I have looked at tons of 3rd party after market ones and gotten some clues from the forum. My question is that Kubota seems to offer 3 version, good to best kinda thing. does anybody know the differences in canopy to "Deluxe Canopy"? if anyone has pictures of the different versions that would be very helpful.
thanks
/ kubota Canopies #2
i have the kubota canopy on my L4400. i believe it is the "best" model. it took about an hour to install, and it is a great addition, especially when it rains or snows.
/ kubota Canopies #3
lots out there, personally I like steel. Nothing special about K. Fiberglass & plastic go down easily w/overhanging branches. good luck bb
/ kubota Canopies
the canopy on your tractor looks really nice. Steel was mentioned. The one on my old JD was steel and pretty glad it was a couple times I caught it on trees. I believe about all the ones I have found on the net though have been fiberglass, ABS or other plastic. Anybody have recommendation on a Steel one?
/ kubota Canopies #5
i hit mine on branches all the time, they just seem to get pushed aside, then again, i am careful about where the canopy i going. if i were going to go do real "woods" work, i would take it off, rather than have it hit everything
/ kubota Canopies #6
I purchased mine for my B3030 from the dealer for $425. I think its the standard one not the deluxe. It is ABS plastic made by FEMCO. So far I don't have any problems with it. It fits well, looks good, and keeps the rain and sun off me.
/ kubota Canopies #7
Someone on one of the forums used a car hood for a canopy. I thought that was a terrific idea. Painted Kubota orange and it could be a lot cheaper. Lots of different sized cars out there, so I figure I can just about pick the size of the hood that I need.
Larry
/ kubota Canopies #8
Steel will radiate heat much more than you may think. That can be good as well as bad. You can insulate it. I have Kubota brand fiberglass on my two and like them. They do fade which I don't like. They have run under many small tree limb (nothing larger than an inch). My brother has an aluminum on his Massey and it looks real good and does not radiate heat anything like steel.
Not suggesting pulling one but some road signs are good size for your use.
/ kubota Canopies #9
/ kubota Canopies #11
Dealer wanted $450 for the plastic one for my M6800. I've got a 4x8 piece of aluminum I'm gonna make one from. I'll put a piece of foam insulation board under it to cut down on heat and sound. Now for my B7800 I picked up a plastic dumpster lid they removed. Almost perfect size and has a decent shape to it, just need to make a frame to support it. I saw one made from aluminum checker plate that looked nice.
/ kubota Canopies #12
When I got my used L3400DT it had mounted on it what appeared to be a Chinese made fiberglass canopy. Because it made such a horrible shaking/rattle sound with the foldable ROPS I ended up removing it and I have been discouraged from replacing it with a better quality one perhaps made by Kubota. Has anyone else had this shaking/rattle sound with their Kubota canopies and foldable ROPS?
/ kubota Canopies #13
I like the fiberglass canopy myself. here is my L5740 with it on and with it off. Takes about 20 minutes to remove and I do that when I am working under the trees.
/ kubota Canopies #14
I just installed the Sun Guard Tractor / Mower Canopy Sunshades yesterday and for the $269, A great deal... Solid, good looking, Nice paint, and FedEx in 3-4 days....
Only recommendation would to place some foam/rubber bewteen the mounting rails and the canopy itself to eliminate vibration....I'm going to pick some up this weekend.
Can be removed in 2 minutes or so with wrenches, Or loosen 1/2 the bolts and hinged and the rops folded in about the same time... I'm going to make some quick release bolts/nut for it....(like a bicycle front wheel nut)
Good
