Kubota BX25D
/ Kubota BX25D #1
carbonacreage
Alberta Canada
Kubota BX25D
Finally got myself a 'baby kub'
Already putting it to work around the acreage
/ Kubota BX25D #5
Congrats on your new Kubota, I owned a BX23TLB and it was a great tractor, best of luck to you!
DevilDog
/ Kubota BX25D
Still trying convince the wife it's far too complicated for her to use
/ Kubota BX25D
Told her it would be like trying to operate the washing machine or vacuum cleaner ! I'll never understand how they work
/ Kubota BX25D #8
Oops... I have been encouraging my wife to get on and try to do a few chores with the BX. I just realized this idea might backfire! :D :eek:
/ Kubota BX25D #11
Congrats on the BX25. I've got a BX23 and I love it. These little buggers are tough as nails and they love to work.
/ Kubota BX25D
Be interested to know if anyone has attached a log splitter to the Bx25 powered by the hydraulics.
/ Kubota BX25D #13
I have. I bought a 3 point splitter from Tractor Supply. It's pretty slow due to the hydraulic flow available via the BX25, but I bought a nice new valve (1 SPOOL PRINCE AUTO CYCLE LOG SPLITTER VALVE W/PB). Kind of pricey, but it doesn't require me to hold the lever down which means I can be getting the next log ready while it works on the current one (it does auto-retract at the end of the stroke). Now if you're splitting smaller logs, this is great. For the bigger ones that have to be run through the splitter multiple times, you're left standing there for a bit while you wait for the slow hydraulics. I'm fine with it, maybe I'll upgrade to a pull behind splitter someday for more speed, but I'll make do for now since the total cost was probably about $1100 which isn't bad compared to some of the nicer standalone units.
/ Kubota BX25D
Hi
Thanks for taking the time to reply and provide some good info it's much appreciated
I will check it out
Thanks again
/ Kubota BX25D #15
/ Kubota BX25D #17
I tried it with the hydralics on both my B and L and found it wanting. Replumbed a rear pto pump and it made a world of difference.
http://www.princehyd.com/Products/Hydraulic-Pumps/PTO
PORTA POTTY (A67714)
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
Komatsu PC220LC7 Thumb Jaw (A68134)
Komatsu PC220LC7...
2017 Ford F-750 Petersen TL3 Forestry Grapple Truck (A66736)
2017 Ford F-750...
2026 57in Rotary Brush Cutter Skid Steer Attachment (A66734)
2026 57in Rotary...
Apparently a YTM dealer went out of business.
Apparently a YTM...
