Comparison Kubota BX25D. Vs Mahindra 22max
   / Kubota BX25D. Vs Mahindra 22max #31
The thing that really swayed me is the guy behind me has a large Mahindra machine and he has had nothing but issues with it,
Any brand can have a bad apple in the barrel.
The 'large' export Mahindras are mostly made by Tym in Korea and are different animals than the Mitsu built machines. I can't speak for their quality, but there are a LOT of them out there, all around the world.
   / Kubota BX25D. Vs Mahindra 22max #32
Mitsubishi as a company has been bleeding red ink for years....
I liked how so much of the Kubota was done in house....
The thing that really swayed me is the guy behind me has a large Mahindra machine and he has had nothing but issues with it, loader, transmission, just this year the radiator blew its side out....
Saying one is for serious work and the other to cut grass and play around the estate is a stupid and uninformed opinion.
....at the time I bought you got the financing deal on their equipment as well....not sure if Mahindra has the same deal going.
Cherokee140, I shortened your post a little, but I think I left everything in context.
If you are indicating that we should avoid Mitsu because they fail to make your investment criteria, that is a real stretch.
I too like how much of Kubota's product is made in house. Worldwide, Mahindra is similar in that it produces a huge majority of it's own tractors and parts. In the USA however, we do sell a lot of the Mitsu product, which is obviously not made by Mahindra.
Radiators blowing out the side are normally due to neglect and gross over heating. However if your neighbor has had a bunch of problems I can understand that you would hold your position that Mahindra is not for you. No doubt word of mouth and happy customers sell tractors, unhappy customers sell tractors for other brands. Occasionally but rarely there is a problematic unit, but other brands have their stories as well. In the larger picture, you will find Mahindras to be quite reliable.
Calling people stupid and uninformed is your prerogative, but generally just gets people fired up and off topic. If you see no duty cycle or longevity issues between a ladder frame/aluminum transaxle sort of SCUT and a conventional design, so be it. Is not a tractor several hundred pounds lighter a better mowing tractor? Is not a heavier more robustly made tractor better at some things as well? This isn't a quality bash, more of a "right tool for the job" point. You can make that point within a brand, it does not need to be brand X vs brand Y. Is your BX25D less of a tractor than the B26? They are about the same HP, same brand, yet one might be a better mowing and estate tractor than the other? I took Mahindra out of the equation to try to make a point.
Mahindra incorporates implements into the financing packages and has for years. Mahindra also uses it's own finance arm, Mahindra Finance USA.
Finally, I'm a Mahindra dealer, but I respect Kubota and I like their product. Like I said much earlier in this thread, a buyer will be happy with either machine.
   / Kubota BX25D. Vs Mahindra 22max #33
Dave, you are being awful darn reasonable, and making a lot of sense to this old Missouri boy!:thumbsup:
   / Kubota BX25D. Vs Mahindra 22max #34
As an owner of a Kubota BX23, I sort of agreed with Cherokee140's "stupid and uninformed" comment on calling a BX25 a lawnmower. Anyone who has bothered to research them or use one knows that the little BX25 can do a lot of work and are much more than a lawnmower.
But I also agree with you on the "right tool for the job". My seat of the pants impression of the Max28 is that it is a heavier tractor built around a larger frame than the BX25 and, as a result, it should get most jobs done more quickly if the main requirement is weight and power as opposed to being nimble (where the BX25 probably wins).
In any event, I salute you for your restrained, unbiased and professional approach to these discussions.
   / Kubota BX25D. Vs Mahindra 22max #35
...Mahindra tractors over 36 horse power are primarily built in India by Mahindra, which is based on International Harvester technology.
All MAX/16 Series (23 - 36 HP) Mahindra tractors are built in Japan by Mitsubishi.
The 10 series are built in Korea by TYM.
Mahindra implements and attachments are built in the USA.
per a dealer
   / Kubota BX25D. Vs Mahindra 22max #36
Does Mahindra offer some kind of quick connect for the fel? Get tired of beating pins trying to get forks off to put bucket on and vice versa. Ours is 4500 early 2000's model.
   / Kubota BX25D. Vs Mahindra 22max #37
Many models come witht the SSQA form of attachment. Which, I cannot tell you. I know the 3016, 3616 and 4000 series do, but beyond that, I'm not sure.
Dunno about factory retro fits but several companies make conversion units for pintype tractors.
Somehere will point you to a dealer.
Eta, here's one
Tractor Loader Universal Skid Steer Quick Attach Hitchs
   / Kubota BX25D. Vs Mahindra 22max #38
per a dealer
Yes...written by a dealer. You know you are going to get nothing but roses from him.
And yes if a company is on weak footing and goes under how well do you think getting parts are going to be. I don't give one rats about the rest of the world I care about service and support here in Missouri.
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A56435)
New Holland 1412...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
backhoe attachment for full size skid steer (A56857)
backhoe attachment...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56435)
2007 Heil Heavy...
