Kubota BX24 Injector pump problem
   / Kubota BX24 Injector pump problem #72
Glad to hear your problem is solved and the
mule is out of the hospital and working again.
I hope you can purchase a Racor diesel fuel
filter or one of their water removing funnels
to keep the water out of the fuel system
shortly as it will be money well spent to
prevent this from happening again.:thumbsup:
   / Kubota BX24 Injector pump problem #73
Glad to hear that you are 'tractorin' again:thumbsup::thumbsup:
   / Kubota BX24 Injector pump problem #74
the 4 cylinder turbo diesel runns fine but when it sits for a while between mowings it losses the consint fuel pressure to the injectors so every time you go to start it you have prime it or you have ti habd pump the fuel filter fuel so it will run. if you just use the starter it will start and die. you do this about a dozen times untill there enough fuel to a couple injectors it will run but misses untill all the air is out of the system and then it runs like good and operates good
   / Kubota BX24 Injector pump problem #75
I was just re-reading this thread after the parts guy at my local dealership asked me if I had replaced my fuel filters recently... It's a bit hard to believe, but it's been 5 years since I installed the Racor filter. I use fuel from busy sources and always use a filter funnel. I'm still on the original Racor filter element and have only drained a bit of fuel out of the bowl once or twice, but that was just because I was down there anyway and it seemed like a good idea. I've seen no contamination in the bowl, water or otherwise. I have no regrets about installing the Racor, but the filter funnel seems like a VERY good investment if used religiously, which I do.
   / Kubota BX24 Injector pump problem #76
8 years of Racor use now and no regrets of problems with the installation. I don't think I've replaced the filter element either, but may have in a weak moment just for the heck of it.
   / Kubota BX24 Injector pump problem #77
My BX25 would not start. I narrowed it down to a fuel problem. I had new fuel and filters and the fuel pump worked. So I took off the injection pump and one of the four little screws holding a plate onto the pump was about half way out. The plate had a slot in it where a lever stuck out. I had to align that lever with a slotted part in the motor, by moving the cut off solenoid to make the parts line up. After putting it all back together, it started. I don't see how that screw being loose could have caused it not to start, but it was very odd that it was so loose, and I saw it right away as it was nearly all the way out!
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
LOT: (4) Barrel Hand Pumps (A59076)
LOT: (4) Barrel...
