Kubota BX24 Injector pump problem
   / Kubota BX24 Injector pump problem #61
Nice job on the install, it's a job well done and looks good besides.
Sean
   / Kubota BX24 Injector pump problem #63
Also used Marvel Mystery Oil religiously (recommended by local dealer)...
The well known Spicer diesel fuel lubricity study pointed out that MM made diesel fuel lubricity WORSE. Maybe your dealer is selling future repairs or just uninformed?
   / Kubota BX24 Injector pump problem #64
- I am also relocating the electric fuel pump in engine compartment. Too much of a pain to access (nothing to do with current problem tho)..
I don't understand this- it is right there very easy to access. I'd be cautious about raising it, may be below tank level for a good reason. Pumps don't suck near as well as they push. :2cents:
   / Kubota BX24 Injector pump problem #65
the link:
http://www.johnfjensen.com/Diesel_fuel_additive_test.pdf
17) Marvel Mystery OilGas, Oil and Diesel fuel additive (NOT ULSD compliant, may damage
2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel
   / Kubota BX24 Injector pump problem #67
Don87
Thanks for the information and the link. Since I'm new to tractors this is good information!
   / Kubota BX24 Injector pump problem #68
Is that a galvanized steel elbow I see in the first pic ?
Nope, not this time...
Thanks for the compliments Chilly807 and Deano! I thought about it for a while... before I came up with the solution for all of my considerations.
A side note, when I installed all of this I was able to fill/bleed the Racor filter bowl by gravity, then took off the fuel line at the injector pump and ran the lift pump (by turning the key to the "run" position) until fuel started to come out of the line. I re-connected the fuel line at the injector pump and was able to start the tractor right up.
12/31/2011
Injector pump replaced. Fired right up.....:)
   / Kubota BX24 Injector pump problem #70
Nice to hear. Thanks for the update!
202476 (A54757)
202476 (A54757)
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
HELI 25 STRAIGHT MAST FORKLIFT (A52709)
HELI 25 STRAIGHT...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2006 Toyota 7FGU60 11,250lb Propane Forklift (A55973)
2006 Toyota 7FGU60...
