Loader Kubota BX23S loader raises extremely slow sometimes not at all
   / Kubota BX23S loader raises extremely slow sometimes not at all
Control valve was good. I neglected to say that I have a Kubota 3rd function valve. Now I am wondering if there is something going on with that valve. I'm going to need to pull the joystick and cover off to take a look under there to see if anything is loose. Used the tractor today and everything runs great except for the loader lift and curl. Backhoe and outriggers work fine and fast. Trying to rule out everything I can before I drain the hydraulic fluid $.
   / Kubota BX23S loader raises extremely slow sometimes not at all #12
Does it have that 4 line connector for the hyd lines on the loader take it off clean it ,make sure its locked down correct ...
Yes. It has the 4 line connector. Removed it a couple of times wiped off.
   / Kubota BX23S loader raises extremely slow sometimes not at all #15
Switch coupler around. For example switch the curl connects to the loader lift arms and see what happens.
I've been grasping at straws for weeks! LOL I'll see if I can switch the coupler around.
   / Kubota BX23S loader raises extremely slow sometimes not at all #17
Does the 3rd function valve work ?
3rd function valve does work, but even the grapple moves very slow.
   / Kubota BX23S loader raises extremely slow sometimes not at all #19
Switching the quick connects around should confirm it is not the cylinders or the hoses leading to them, it will also take the third function out of the equation.
Well, no go on everything I've tried. Sent an email to the dealer to see if they can pick it up :( Stay tuned.....................
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
Stout Brush Grapple (A59814)
Stout Brush...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A60460)
2012 Vermeer...
2022 John Deere R4023 (A60462)
2022 John Deere...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2007 Volvo VNL Truck Tractor (A56438)
2007 Volvo VNL...
