3-Point Hitch Kubota BX2350 . 3 point hitch problem
   / Kubota BX2350 . 3 point hitch problem #11
It's possible the previous owner locked them up if he was just using the deck, and didn't want the arms to move up and down with the deck. To lock the arms in the up position is a different thing - you use a pair of tabs on the frame up by the 3pt arms with a hole in them, and pin the arms up.
Wow! Learn something new everyday! I wonder if this is the same on my BX2200? Have to take a look... :thumbsup:
Intellectual curiosity only. Have no reason to want to pin mine up... :)
   / Kubota BX2350 . 3 point hitch problem #12
Just a guess here, but on my BX2350, if I don't have something on the three point hitch, the arms often won't lower, but if I put my foot on one of the arms and push down, it will go down.
   / Kubota BX2350 . 3 point hitch problem #13
I wasn't sure if they were on pre-50 series, but it looks like they are. Here is a thread on pinning the 3pt up. There is a picture showing the newer style tabs, and another picture of a 2200 in a post in that thread further down. The tabs are shaped differently on the 2200 than the later models.
You unpin the top of the vertical link arms, and pin them to these tabs.
http://www.tractorbynet.com/forums/kubota-owning-operating/220584-stop-3pt-hitch-dropping.html
Thank you all so much for the advice. I soaked the shaft overnight in WD 40 and with a bit of gentle persuasion got the 3 point hitch drop speed knob turning this morning. And yes...the three point hitch now works fine....very pleased.....
The tractor had been left outside for a while and is a bit neglected but I will get it back. Next jobs are to unseize the little black mower wheel shafts, and source one of these wheels...it only came with three. I also need to do some engine maintenance.
   / Kubota BX2350 . 3 point hitch problem #15
glad you got sound advice from others before i chimed in about 3 pt. to source parts just go to messicks.com and do the drop down list of the model you have and just order parts you need. so simple. its a good idea to do engine oil change and hydraulic oil change so you know the "start" of next maintenance. and you know whats in it. be sure to use sudt for hst oil.
   / Kubota BX2350 . 3 point hitch problem #16
Good to hear it worked out. Have fun!
Thanks, but I doubt Messicks will deliver to me here in France. What is sudt?
   / Kubota BX2350 . 3 point hitch problem #19
As mentioned already, the same lever raises the deck and the 3pt arms. You can lock the deck up, so you can lower and raise the 3pt without the mower moving, by setting the deck height knob under the seat at the floor to "Top". The other knob is the flow rate knob which will control how slowly or quickly it will move depending on how much you close it. If you close it all the way, it won't move at all. It sounds like that is frozen right now, but not in the closed position if the deck is moving up and down - it is not closed.
Sometimes if the flow control is set quite closed (mower deck moves up and down slowly), the 3pt arms will hardly move without something attached, as there is just no weight to pull them down. Try moving your control lever to lower the deck, and put your hand on one of the 3pt arms and press down. See if the arms move down once you put weight on it.
If they still do not move down, make sure they haven't been locked (pinned) in the up position. It's possible the previous owner locked them up if he was just using the deck, and didn't want the arms to move up and down with the deck. To lock the arms in the up position is a different thing - you use a pair of tabs on the frame up by the 3pt arms with a hole in them, and pin the arms up. I'll see if I can find a picture, but if you look back there is should be pretty obvious if the arms are pinned into those tabs.
-- I have a BX2200 and 2 B2150's. As GolfAddict and others said , all of them have a single control lever for raising and lowering the 3pt hitch and the belly mower. There is no separate hydraulic system for the two functions.
-- All these smaller Kubotas have a kind of make-shift rod (seems like flimsy design to me, but it works) running from a piece of sheet metal hanging over the 3pt lower arms forward to levers that then raise the MMM deck. Notice I said raise, I did not say lower.
-- Virtually none of the tractors these days have dual acting hydraulics that force things downward as well as lift them up. I have an old Massey Harris Pacer that does both, but these Kubota's sure don't.
The result is that anything going downward -- be it your rear 3pt lift arms attached to lower arms with an implement on them or your MMM deck are all going down by force of gravity, not hydraulics.
-- OK, so there probably is some way to pin or restrain the two cast iron lift arms from dropping. That is NOT done by any knob or control as someone else had said.
-- As a couple of guys said, just push down on the arms and they will go down; might take some force but not a whole lot. Unless the arms have been fastened up which seems unlikely to me & if they were fastened up you should be able to see that.
-- The fact that you got the "speed of lowering" knob loosened up is great but that was never keeping your arms from lowering in the first place.
By the way, it hasn't been mentioned but DO NOT try to raise or lower your deck with the height setting knob unless the deck is lifted to the uppermost point. The weight of the deck rests on the mechanism that adjusts height except when the deck is fully raised. You will break the plastic height setting knob off trying to move it up or down unless the deck is raised fully (so that the hydraulics is supporting the weight of the deck.)
Good luck with your machine.
Thanks a lot for this advice....Peter
Hustler super Z zero turn (A56857)
Hustler super Z...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2021 Ford F-450 (A55973)
2021 Ford F-450...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
