Kubota BX2200 - 3point log splitter
   / Kubota BX2200 - 3point log splitter #11
apfaff said:
Thanks everyone! I hooked the pressure line up just before it enters the fel controls and disconnected the fel completely from it. It worked great! Like you said I just need to make sure I connect the fel back in whenever the splitter is disconnected so it doesnt dead-head.
Bottom line, the fel control valve bleeds the oil to tank when the handle is not being used and in neutral position.
Only remaining question I have is which tank line is the best to use (there are two). The 'from implement' or the 'return' line? I assume only 1 goes through the filter, likely the 'from implement side'. Does anyone know for sure?
Thanks again
apfaff,
Try this post that I just brought back to life on setting up rear hyrdraulics for your BX2200. I did this on mine, when I onwned it and it worked out awesome! But it is gone and now I have the B7510!
http://www.tractorbynet.com/forums/kubota-owning-operating/14585-added-rear-hydraulics-bx2200.html
404 (A52706)
404 (A52706)
48" Pallet Forks (A59814)
48" Pallet Forks...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
Compact Track Loader Skid Steer (A59228)
Compact Track...
