Kubota BX22 - LA210 - Lifting Issues
   / Kubota BX22 - LA210 - Lifting Issues #1
Calvin Cassady
Northport, Alabama
Kubota BX22
I have owned my BX22-LA210-BT600 since 2003. It has about 320 hours. I have serviced it properly and it runs great. Today the LA210 Front End Loader lost power to lift. I could run the RPM up and dump the bucket and raise the bucket empty. Bucket roll seems fine. Back hoe seams fine. I disconnected the Backhoe, but did not solve problem. I rebuilt the lifting cylinders about a year ago, and they have worked fine since. I check the 3 quick connects and one look like it had old oil in it. 3PH level is in the neutral position. Any ideas? Thanks
   / Kubota BX22 - LA210 - Lifting Issues #2
Is the valve spool for lift/ lower moving fully. If like my Bx1850 there was several linkage points between the joystick and the directional valve hidden behind the dash panel. If one of these linkage points worked loose and allowed only a partial shift of the spool this could explain your problem.
   / Kubota BX22 - LA210 - Lifting Issues #3
Check linkage as stated by oldnslo.
Does your valve spool go into float?
If you can, observe the spool and determined if the spool when operated, moves in and out equally except float has a little more travel.
You could also measure the flow from both spools and determine if the valve is providing full flow, using a 5 gal bucket and determine GPM.
   / Kubota BX22 - LA210 - Lifting Issues #4
Why not purchase a lift valve with PB and install it first and then run the log splitter and the lift valve OUT to tank.
Lift,split, lift ,split, or not lift.
You only need to hyd lift the large chunks.
   / Kubota BX22 - LA210 - Lifting Issues #6
Short of doing some flow Vs pressure tests on the FEL circuit I don't have any other easy to do suggestions.
   / Kubota BX22 - LA210 - Lifting Issues #7
Did you do any of the things I suggested in post #3?
   / Kubota BX22 - LA210 - Lifting Issues #8
Why only 3 QD? Did you overlook one?
The joy stick / valve does lock in to float mode. I have not done any flow test. Tractor parts man thinks it is a cylinder bypassing inside. I am considering rebuilding the cylinders again.
   / Kubota BX22 - LA210 - Lifting Issues #10
He might be talking about the FEL valve IN QD, the OUT QD and the PB QD., and not the 4 work ports.
2006 MACK CV713 KILL TRUCK (A52472)
2006 MACK CV713...
Chery 6ft 10 Drawer WorkBench (A50325)
Chery 6ft 10...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
